Thread: MAP and Boost gauge
Results 1 to 7 of 7
gotboost3 MAP and Boost gauge 07-01-2009, 11:13 PM
minichopper6hp Re: MAP and Boost gauge 07-01-2009, 11:35 PM
Sabrewings Re: MAP and Boost gauge 07-02-2009, 11:12 AM
gotboost3 Re: MAP and Boost gauge 07-02-2009, 12:04 AM
minichopper6hp Re: MAP and Boost gauge 07-02-2009, 12:53 AM
minichopper6hp Re: MAP and Boost gauge 07-02-2009, 11:33 AM
Sabrewings Re: MAP and Boost gauge 07-02-2009, 12:49 PM
  1. #1 MAP and Boost gauge
    Donating Users
    Plainfield, IL
    ok guys a little confused my map readings through my aero are always diff then what my mechanical boost gauge reads....at idle i get 20.1 vac on the aero and the boost gauge reads at 18.5 vac.....why is this? could it be a flaw in the line running to the gauge?
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: MAP and Boost gauge
    Banned - Busted For Scamming
    Feb 2009
    mechanical is always more accurate than electric gauge.
    FWIW, i see straight 20 in hg when im at idle.
  3. #3 Re: MAP and Boost gauge
    Barksdale AFB, LA
    That's way too vague. It depends on who makes it. The factory MAP sensor is very accurate, and I'd be inclined to believe it over any aftermarket gauges.
    2009 Subaru Impreza WRX STI
  4. #4 Re: MAP and Boost gauge
    Donating Users
    Plainfield, IL
    i get 19 is that normal?
  5. #5 Re: MAP and Boost gauge
    Feb 2009
    yep, perfectly.
  6. #6 Re: MAP and Boost gauge
    Feb 2009
    Electrical gauges have too many variances
  7. #7 Re: MAP and Boost gauge
    Barksdale AFB, LA
    Again, it depends on who makes it. A quality electrical gauge is just as accurate as any mechanical gauge. Any variances in the system voltage are accounted for with voltage regulators. Here's a hint, no gauges on the aircraft I work on are mechanical and they're accurate to within a thousandth of a percent of their range. Moste electrical gauges these days use air core motors which are more precise in their movements than mechanical gauges.
    Autometer makes awesome electrical gauges that are 100% as accurate as their mechanical brothers. GM's OEM senders are just as accurate, with the PCM being the "gauge" and it definitely has its own electronics to handle any electrical instabilities.
  1. Boost Gauge?
    By ChrisJ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2009, 01:56 PM
  2. Boost gauge...
    By WayneG99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 08:52 PM
  3. boost gauge and etc...
    By Charged97 in forum General Tech Discussion
    Last Post: 02-28-2009, 04:16 AM
  4. Boost gauge on 03 gtp
    By brodyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2008, 08:06 PM
