I have had some problems with my car shutting off randomly. Replaced PCM and that did not fix it, so I unhooked Mass Airflow Sensor and it has seemd to be running ok, at least not shutting off.
Yes the engine light is on.
Take it to your local autoparts store and have then scan it. Generally its free and they can tell you what code comes up. Once you have the code, you can either let us know.. or do some research to see what it is.
Thanks for th info, I will post in the correct forum next time. "Damn Newbies"
haha geddylee has some work to do... =P
moved to correct section..
