Thread: More Exhaust Help
Results 1 to 16 of 16
  1. #1 More Exhaust Help
    So I got my DP installed and it sucked. It took 14 times longer then it should have, nothing went together well, and to top it off it sounds like s h i t. I got it done and took it for a cruise and it sound horrible. At highway speeds it really doesn't sound much different but at about 2K rpms it sounds bad. It sounds like a old rusty car that is falling apart. Is this normal for an Off Road pipe or is something wrong? If it sounds like this because of the lack of a Cat, would a muffler shop weld in a cat for me and what would it normally run?
    To be honest, I wish I would have never even done this. It was very frustrating and it sounds horrible now. I don't even know if there is more power because the sound just made me sick. I know my dad is not going to be happy with the sound at all either.
    Please help me out guys.
  2. #2 Re: More Exhaust Help
    Banned
    Wichita Falls, Texas
    Do you have a resonator still? I'm assuming not.
  3. #3 Re: More Exhaust Help
    No it is still there
  4. #4 Re: More Exhaust Help
    Donating Users blowfishRus6's Avatar
    g.a.
    no exhaust leaks??
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  5. #5 Re: More Exhaust Help
    Racine, WI
    You have an exhaust leak most likely.
  6. #6 Re: More Exhaust Help
    Well I bolted in a Cat today and it sounds better. All of my bolts seemed tight. The cat quieted it up a bit and got rid of the bad noise around 2k for the most part. It is still kind of there though. I still do not like the sound to be honest. I wish it was still stock.
  7. #7 Re: More Exhaust Help
    g.a.
    maybe a gasket is not on right or something.. ?? ..
    its slow.
  8. #8 Re: More Exhaust Help
    May 2008
    McHenry IL
    im not messin with my dp
  9. #9 Re: More Exhaust Help
    Moore, Oklahoma
    You got a leak or something, my other GTP has a 3" offroad downpipe to a stock cat-back and it sounds like a stock GTP, it is not noticeble louder at all, you'd never know its there. No drone, no nothing. It actully too quiet.
    Surely you used new gaskets right? If not, pull it off and start all over. Get new gaskets.
    A 3" downpipe + u-bend removal is the best mod you can do for these cars period. Most everyone here won't gain a damn thing by changing the cat-back, the restriction is at the downpipe + u-bend. Stock Catback actully flows pretty damn good, its the best part of the exhaust by all means.
    Shawn W. Larsen
  10. #10 Re: More Exhaust Help
    May 2008
    staten island,NY
    you have a leak. did you bother to change the gaskets on the exhaust manifold and the catback? you wasted money on a cat for nothing, you coulda took it to a muffler shop and they woulda replaced the gaskets and installed it for you for now more than $50
  11. #11 Re: More Exhaust Help
    I put new gaskets in and made sure the surfaces were cleaned before I installed them. I will check for leaks on Wednesday. I have to drive 3 hours tomorrow. Will it hurt it having a leak?
  12. #12 Re: More Exhaust Help
    May 2008
    staten island,NY
    no its just going to sound like crap, you must have not installed something correctly for the leak to be this bad
  13. #13 Re: More Exhaust Help
    May 2008
    McHenry IL
    i hope mysystem doesnt sound like ass when im done with her 2 =[ i hope u get her the way you want her to sound man!
  14. #14 Re: More Exhaust Help
    SE Level Member VALIANT's Avatar
    Chicago, Illinois
    Hope you find the answer to your problem... My catback system is stock and will stay that way... well only change when needed. Like the fact that it is so quiet, that is until I get on da gas! lol
    Good luck with your problem.....
    4.2 Stroke
  15. #15 Re: More Exhaust Help
    Donating Users ROTTMAN's Avatar
    Feb 2009
    canada
    Quote Originally Posted by VALIANT View Post
    This thread is a year old.
  16. #16 Re: More Exhaust Help
    quebec, canada
    if i remove my cat conv. what sort of side effects could occur? what about the egr? any proper way of doing these?
  1. Exhaust Help
    By TCO in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2008, 08:26 AM
  2. exhaust Q
    Last Post: 06-19-2008, 10:26 PM
  3. exhaust
    By zach_gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-22-2008, 11:06 AM
  4. exhaust
    By crshoveride in forum Off Topic Discussion
    Last Post: 03-13-2008, 02:40 PM
