Thread: XPZ pedistal spacer thickness?
Results 1 to 1 of 1
Threaded View
  1. #1 XPZ pedistal spacer thickness?
    Elkhart, IN
    Running XPZ, Stage 3 ZZP heads (only milled .005), OEM L26. Have push rods 7.050 Exhaust and 7.100 intake. I am having a hell of a time figuring spacer thickness required. Anyone with this set up remember what they used to get me in the ballpark? Right now I have .063 pedistal spacers installed.
    But I am having a hell of a time getting accurate preload as there is not much room to fit my hands in there to spin the push rod.
    Here is what I think I know at this point:
    .1" extra valve height (longer per ZZP) / 1.6 = .0625
    .035" (radius) less on the base circle for the XPZ
    7.02 - .0625 + .035 -.005 (head milled)= 6.9875" ideal pushrod without pedistal spacers
    Now I use 7.050 exhaust and 7.100 intake so I am gonna use middle of the road 7.075 for calculation.
    7.075-6.9925= .0875 difference
    How in the hell with the 1.6 : 1 ratio do I take that .0875 and figure the correct shim needed? I have a headache.
    I am thinking: 1.6 x .0875 = .0546875
    .0546875 + ( .0328125 ) = .0875
    .0546875 - .0328125 = .021875
    .021875 / 2 = .0109375
    .0109375 + .0328125 = .04375 (pedistal shim needed)
    Like I said, I have .063 in there now. Maybe that is too much? Have to look at that when I get home.
  1. How to remove TB spacer, attached with RTV
    By 04CompG in forum General Tech Discussion
    Last Post: 06-21-2009, 03:22 PM
  2. rotor thickness
    By Wadeb79 in forum Brakes/Suspension/Chassis
    Last Post: 04-27-2009, 12:10 PM
  3. S/C spacer?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2009, 09:09 PM
  4. wood IC spacer
    By 04DetroitLS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2008, 05:25 PM
  5. TB spacer?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2008, 06:43 PM
