Thread: Troubleshooting Help! 02 GTP - DIC/ AC Issue
Results 1 to 20 of 20
  1. #1 Troubleshooting Help! 02 GTP - DIC/ AC Issue
    Outer Space
    My DIC has been going on and off lately, no big deal right? Wrong! When the DIC goes out, I can't turn on my A/C. Flip the switch and nothing. If its night time and my DRL are on... I turn the A/C switch to 1 and the lights go off. Turn it back to off and the lights come back on.
    I ordered a replacement DIC from Ed... but what else should I look at?
    02 GTP 13.6 @ 100mph - SOLD
  2. #2 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    PA
    Quote Originally Posted by Lawngoose View Post
    I would bet your ignition switch is going bad. Have Ed send one along as well.
    2001 GSE
  3. #3 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    Outer Space
    DOH! Thanks Zef.... I was fearing that response... lol
    So replace the ignition switch cause its affecting my DIC too? I was thinking it could be blower motor resistor, since I lost 1-4 when my DIC was off, but I normally could get 5. Until today
    What about an ignition bypass? http://www.grandprixforums.net/ignition_bypass.php Yay or Nay?
  4. #4 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    Yay if you like wiring LOL I could never do that in my lifetime I say get the switch changed and if it doesn't work THEN do the bypass...just one of those things if you don't have to do it then don't ya know?
  5. #5 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    PA
    As far as I know, the ignition bypass does not fix a bad ignition switch. But it will help prevent a good ignition switch from going bad again.
    2001 GSE
  6. #6 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    GT Level Member Egleone6's Avatar
    Springfield, Illinois, United States
    Stupid question. What is DIC?
    If my pics are not working, please email me, I may have moved the pics on a different page on Photobucket. Thanks
  7. #7 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    PA
    Quote Originally Posted by Egleone6 View Post
    Driver's Information Center.
    2001 GSE
  8. #8 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    Ahh. Just to be short, my blower does not work on settings 1-4 bt on high. I have not noticed the DRL (daytime running lights) not working. I will check that out later. I was told to replace the resistor on the blower motor. Is this not right? Please lemme know.
  9. #9 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    PA
    Probably either the resistor or the ignition switch. But I would start with the resistor first.
    2001 GSE
  10. #10 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    Well I got it fixed, it was the Resistor on the Motor. Costs 28 bucks for the part and buddy at an Auto Body shop fixed it for 15 bucks, or I buy lunch. lol Thanks for the info.
  11. #11 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    Feb 2010
    NY
    the resistor on the blower motor?
  12. #12 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    Outer Space
    Resistor worked for him... however... in my case it WAS the ignition switch. Replaced it and have been fine since.
  13. #13 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    SE Level Member NoTyme's Avatar
    southeast Michigan
    Can you tell me where that resistor for the blower motor was located on your car? I can't seem to get close to finding mine.
  14. #14 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Yep, it's on the blower. And a pain in the a&& to swap out...
    Lambokit to be built!!!!!
  15. #15 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    southeast Michigan
    Quote Originally Posted by lambokit View Post
    Is it in the area of the glove box or more like in the center of the dash, like behind the console???
  16. #16 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    SE Level Member TEBO's Avatar
    Apr 2009
    My step mom's 02 GT is having this same problem, how much is the ignition switch?
    *sig too tall, 200 px or less*
    98 Grand Prix GT(green)
    In trunk computer
  17. #17 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    Outer Space
    Quote Originally Posted by TEBO View Post
    I bought a used one from moradpartscompany.com for like $45 shipped.
  18. #18 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    southeast Michigan
    Just a follow up: replace the resistor and the blower is working fine on all speeds. Thanks for the info...
  19. #19 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    Apr 2009
    Does anyone have a write up on this?
    In trunk computer
  20. #20 Re: Troubleshooting Help! 02 GTP - DIC/ AC Issue
    Apr 2009
    In trunk computer
  1. Transmission Whine Troubleshooting PLEASE HELP
    By rworkman98 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-25-2008, 12:57 PM
  2. Troubleshooting Help! p0120 & p0121
    By Lawngoose in forum General Tech Discussion
    Last Post: 10-25-2008, 05:10 PM
  3. Troubleshooting Help! - A/C Problems
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-21-2008, 04:07 PM
  4. Grand Prix DTC Troubleshooting [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-16-2008, 02:07 AM
