Thread: Turning/Steering Noise
Results 1 to 3 of 3
  1. #1 Turning/Steering Noise
    SE Level Member chisels1's Avatar
    Massachusetts
    What could this be? I have a 1992 GPSE and when turning or steering, left or right, especially when pulling out of a street or trying to park it feels like a lack of power in the steering and there is a very noticeable straining type squell.
    Is it a belt?
  2. #2 Re: Turning/Steering Noise
    SE Level Member pureevilz28's Avatar
    Apr 2009
    USA
    sounds like the ps pump is bad. or you got some air in the system or just low on fluid.
    2002 Z28 M6-Boltons, Comp 233/239 cam, Pacesetter LT's, dynomax bullet(dumped), autometer gauges, HP Tuners.
  3. #3 Re: Turning/Steering Noise
    Massachusetts
    Well, I have cured the Steering Noise issue.
    Power steering fluid a bit low, so I topped it off and then with the engine running at around 2000rpm I turned the wheel hard left then right getting the pump to assist.
    I then got some brake cleaner and sprayed some on the inside of the belt with the engine running, being careful not to get showered.
    Car is quiet as a mouse.
  1. Noise coming from steering wheel????
    By jmack98 in forum General Tech Discussion
    Last Post: 04-26-2011, 05:41 PM
  2. Power steering pump noise
    By minichopper6hp in forum General Tech Discussion
    Last Post: 07-18-2009, 01:57 AM
  3. Key not turning back all the way.
    By DJO in forum General Tech Discussion
    Last Post: 04-14-2009, 09:03 PM
  4. Turning a 01' SE into a GT
    By Dangerous313KidInAPrix in forum Visual/Body Modifications
    Last Post: 03-03-2009, 09:17 PM
  5. TCS not turning off
    By Keet04GTP in forum General Tech Discussion
    Last Post: 08-06-2008, 02:57 PM
