have you been using your a/c??? the a/c drain is on the same side your getting water on. look behind your motor and you will see a rubber 90 coming out of the fire wall. thats your a/c drain and if it clogs up you will get water in the car
Well guys I've concluded that it is NOT rainwater, but condensation building up that is causing my wet passenger floorboard.
So its the condensation from the ac. I looked up under the dash and the water is leaking from where the rubbing hose connects to the bottom on the ac unit. I pulled that rubber hose off and its no clogged.
So, how do I get this ac condensation to drain properly? For now I just wont run ac, but its summer of course and I'd like to get this fixed as soon as possible.
