Thread: problem with windshield wipers - 98 gp
Results 1 to 4 of 4
jbeu3936 problem with windshield... 08-08-2008, 06:08 PM
gtpinsc Re: problem with windshield... 08-08-2008, 11:51 PM
archemedes Re: problem with windshield... 08-09-2008, 02:44 AM
BigG Re: problem with windshield... 06-29-2009, 05:00 AM
  1. #1 problem with windshield wipers - 98 gp
    Aug 2008
    brimfield, ma
    Hello,
    I just purchased a 98 grand prix gt, and the windshield wipers will not return to the home position. They seem to work fine, but stop in the upward position on the windshield. Any help would be greatly appreciated. Thanks.
  2. #2 Re: problem with windshield wipers - 98 gp
    Jul 2008
    sumter,south carolina
    pop them off ... there should b a little latch on wipers open that and and pull back on wiper it will pop off then realign where u want and close latch
  3. #3 Re: problem with windshield wipers - 98 gp
    Saraland Alabama
    there is a metal piece that may be bent (can't remember exactly where it's at as I have not had the issue, but have read the fix a few times) look here http://www.grandprixforums.net/f81/h...pers-2185.html
  4. #4 Re: problem with windshield wipers - 98 gp
    SE Level Member BigG's Avatar
    St. Louis
    Pop the caps off the WW shafts. Loosen the 13mm nut, on each shaft. Pull up on the WW base to loosen it on the shaft. Then move both Wipers down to where their supposed to be. Tighten the nuts back up, put the caps back on.
  1. wipers
    By UR LOSN in forum Visual/Body Modifications
    Last Post: 03-11-2009, 12:58 PM
  2. Windshield fluid doesn't come out
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 12-02-2008, 02:29 PM
  3. how to fix wipers?
    By Dohner in forum General Tech Discussion
    Last Post: 03-07-2008, 04:35 PM
  4. windshield wiper help
    By maybe_memories in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2008, 02:48 PM
  5. Cracked windshield
    By wayne1981 in forum Visual/Body Modifications
    Last Post: 12-16-2007, 10:42 AM
