Thread: intake
Results 1 to 20 of 37
  1. #1 intake
    Donating Users
    Plainfield, IL
    hey guys once i get my 3.4 and tune done in a couple weeks should i favor a short ram open cone behind the headlight for better flow since im running more boost now or just stick with the tdc fwi?
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: intake
  3. #3 Re: intake
    Banned - Busted For Scamming
    Feb 2009
    you still doin that ported blower?
  4. #4 Re: intake
    Donating Users
    Plainfield, IL
    its on my agenda bro! i got 4 things i gotta knock out....3.4*ported blower*lower my car*tune
  5. #5 Re: intake
    Feb 2009
    eh... lowered cars look nice, couldnt drive mine anywhere though it sat too low. got ur blower ready when you are though.
  6. #6 Re: intake
    Donating Users
    Plainfield, IL
    thats why im buying those slp springs in the fs section only an inch drop
  7. #7 Re: intake
    Donating Users
    Plainfield, IL
    you have the ported case done already? is it just outlet work ? or inlet too?
  8. #8 Re: intake
    Feb 2009
    i went ahead and smoothed the inlet for you too, no extra price of what we talked about, just do a review when you get it and i will be satisfied.
  9. #9 Re: intake
    Feb 2009
    i hope they are only an inch drop, if my eibachs were actually that what they said 1.3 inches, i would have kept them on. But when i took them off i measured again and it was over 2 inches of drop!!
  10. #10 Re: intake
    thats why i like my eibachs. so long as i would keep the offset in check i could run nearly any rim i want.
  11. #11 Re: intake
    Aug 2008
    Long Island, New York
    with just a 3.4 i guess you should stick with the FWI... i wouldnt switch to open cone unless i had a serious setup with a cam, intercooler, or meth injection on like a 2.8 inch pulley
  12. #12 Re: intake
    Quote Originally Posted by 2000GTP View Post
    man's got it right
  13. #13 Re: intake
    Donating Users
    Plainfield, IL
    man's got it right
    thats what i was thinking
  14. #14 Re: intake
    Barksdale AFB, LA
    I'm going open cone when I put on the IC. The IC is just going to cool it down anyway, so every little bit of flow helps.
    If you don't have an IC, you want the incoming air as cool as possible. The cooler the air starts, the cooler it'll be after the rotors are done with it.
    2009 Subaru Impreza WRX STI
  15. #15 Re: intake
    GT Level Member BIGTMANE's Avatar
    OHIO
    ok, please help. i went with the short ram (just for a little while) and i cut the top of my air cleaner box (because in the air cleaner box there are wires going into it, and i really dont know what they do so i havent moved it) everything else was stock. do you think this was a bad idea? i mean its not hurting anything right? it should be helping even though its getting more warm air than cold? its still more air. what do you guys think?
  16. #16 Re: intake
    So...you put the aftermarket cone filter in the stock air box? I guess that is fine...it is like the gutted air box mod for the 97-03's...what you can do is take the entire box out and cut out the front of it too for even better flow...
  17. #17 Re: intake
    OHIO
    Yes, pretty much something like that. I cut the top off the box, so the cone filter isn't sitting "in" it, its kinda sitting "on" it. Lol. I ghetto rigged it up. Its almost like its pulling in warm and cold air. I might be able to post pics tomorrow. If I can copy a picture into the reply box. I never tried it.
  18. #18 Re: intake
    Quote Originally Posted by BIGTMANE View Post
    Use photobucket...way easier. Just copy the URL to the post and the pic will appear. Magic.
    Just run a pipe to the inlet of the stock box IMO and put a cone filter IN IT, not on it
  19. #19 Re: intake
    TDCRacing
    Guest
    I've always been a fan of the FWI. I've run it on my 2.8 setup for over a year now.
    I took it off for some reason or another and man. What a performance drop I noticed the second I got back in and started driving it.
    That's all I know. And that's all I can say.
  20. #20 Re: intake
    TDCRacing
    Guest
    All those wires going inot your Air box is for the PCM. You can take it out easily.
  1. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  2. Intake Q
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2008, 02:35 PM
  3. intake
    By SahotaGTP in forum General Tech Discussion
    Last Post: 06-26-2008, 11:02 PM
  4. Intake for 97 GTP
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 03-04-2008, 05:19 PM
