Quote Originally Posted by Scimmia View Post
There's no real benefit to deleting it, other than cleaning up the engine bay and having one less thing that can go wrong. All you really need to do is cap off the vac fitting on the TB and cap off the line going back to the tank, then remove the lines/valve and set the codes to not report. Personally, I would also unplug the vent valve back by the fuel filler neck, but it wouldn't be necessary. If you really want to delete the system completely, you'll need to drop the tank to remove the charcoal canister.
ok where is the vent valve? and where is the tank im assuming its the big black cicrle on the firewall with the big hose from the t tree going to it?
