Thread: I need to replace the fuel pump assembly, need a little help!
Results 1 to 11 of 11
Crcblonde1 I need to replace the fuel... 06-01-2009, 08:26 PM
dagger Re: I need to replace the... 06-02-2009, 01:18 PM
Sabrewings Re: I need to replace the... 06-02-2009, 07:15 PM
SlowRR Re: I need to replace the... 06-02-2009, 07:18 PM
Bio248 Re: I need to replace the... 06-02-2009, 07:34 PM
Guest Re: I need to replace the... 06-02-2009, 09:43 PM
SlowRR Re: I need to replace the... 06-03-2009, 07:25 PM
Suaveat69 Re: I need to replace the... 09-08-2009, 03:01 AM
jigwynn Re: I need to replace the... 05-02-2010, 10:12 PM
dumdin Re: I need to replace the... 05-08-2010, 03:41 AM
Myprixxx Re: I need to replace the... 05-09-2010, 04:25 AM
  1. #1 I need to replace the fuel pump assembly, need a little help!
    Woodstock, IL
    My fuel sensor went out on my 2005 Grand Prix GT this past winter, now I am starting to have problems and I believe its my fuel pump. My dad is going to replace it for me but needs a little direction of where to start! Can someone help direct me in the right direction?
  2. #2 Re: I need to replace the fuel pump assembly, need a little help!
    CT
    remove all that crap from your trunk, pull up the rug and where the spare tire are and its under there. Should be a couple of bolts holding down the plate to get in there. Should be all set after that.
  3. #3 Re: I need to replace the fuel pump assembly, need a little help!
    Barksdale AFB, LA
    I don't think the 2005 models have the access door...
    2009 Subaru Impreza WRX STI
  4. #4 Re: I need to replace the fuel pump assembly, need a little help!
    GT Level Member SlowRR's Avatar
    Brookfield, IL
    that would be some BS, finnaly had it in a 2000 but went back to no access in the new body
  5. #5 Re: I need to replace the fuel pump assembly, need a little help!
    Quote Originally Posted by SlowRR View Post
    what do you mean 2000? i have it in my 98...
  6. #6 Re: I need to replace the fuel pump assembly, need a little help!
    TDCRacing
    Guest
    I think he meant he finially had it in one of his cars. One of which is a 2000.....
    Maybe?
    Man if they don't that sucks.
  7. #7 Re: I need to replace the fuel pump assembly, need a little help!
    Brookfield, IL
    Quote Originally Posted by TDCRacing View Post
    Maybe?
    yep thats what i meant, after many years of 3rd gen f-bodies and other late 80 early 90s cars i owned it was a great day changing the fuel pump on the 2000gtp. Kinda figured it was something that would have stuck around.
  8. #8 Re: I need to replace the fuel pump assembly, need a little help!
    Pittsburgh
    2004's have the access door.
  9. #9 Re: I need to replace the fuel pump assembly, need a little help!
    cleveland
    2001s have a door as well. Made mine a breeze!!!
  10. #10 Re: I need to replace the fuel pump assembly, need a little help!
    london
    remove them out and change new one at shop. Your replacement not mauch with original parts.
  11. #11 Re: I need to replace the fuel pump assembly, need a little help!
    SE Level Member Myprixxx's Avatar
    Apr 2008
    Decatur, IL
    Quote Originally Posted by dumdin View Post
    if you do have the access door i dont believe the spare has to come out.. IIRC the 97 i parted out had the door right behind the rear seat pass through.. just a few bolts to get the door off, wouldve taken all of an hour from start to finish
    i knew this guy wasn't b/sing.
    michigan people have better stuff to do, like finding jobs or avoiding robbery.
    quoted from noreasonwhyy
    GenV, Full sized I/C, HAI, 3.0 MPS, N* TB
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Help! fuel pump?
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2009, 11:50 AM
  3. Fuel pump??
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2008, 03:25 AM
