Quote Originally Posted by FuglyGTP View Post
I found the largest leak. It turns out that when i cut the opening in the largest gasket I also cut away some of that silicone bead and didn't put any rtv on it. After RTVing, and assembling it all, there was only a very slight leak
Should I expect any improvement after the RTV dries?
Well...the deal with RTV is you have to let it cure...so if you started it right after you got done with it, there is prolly a pretty safe bet you need to re seal it and let it set for 24 hours IMO.
