Thread: 97 Grand Prix GT ?'s <----New Guy
Results 1 to 9 of 9
  1. #1 97 Grand Prix GT ?'s <----New Guy
    Scottdale, PA
    I am having some issues with my car.
    The ABS light, Check Tire Pressure, and the Traction Control lights are on. I think it is the Front drivers side Wheel Speed Sensor it started giving me problems a few days after washing my car i sprayed inside the wheel to clean the rim and wheel and there was smoke very little or steam coming from it i thought it was just the heat generated at the wheels and brakes from the water hitting it i started having issues with the lights a few hours later driving wise.
    Other issue i am having is fueling up i cannot put the pumps on auto fill they stop automatically everytime, The little metal clasp inside where you put the fuel in is bent inward a little bit and i don't know what the problem is or how to fix it.
    yet another problem is it is running hot runs a little after the 210 on the guage was thinking it maybe the fact that the Antifreeze lookes kinda gumed up or maybe the Tstat not sure but going to see about changing out the Tstat soon if there is anyone with any pics of the location of the Tstat on a 97 Grand Prix GT i thank you in advance.
    Thanks for your help in advance or any input for that matter.
  2. #2 Re: 97 Grand Prix GT ?'s <----New Guy
    Scottdale, PA
    bump ?
  3. #3 Re: 97 Grand Prix GT ?'s <----New Guy
    Scottdale, PA
    ? is there anyone out there that may know anything about these issues ?
  4. #4 Re: 97 Grand Prix GT ?'s <----New Guy
    GT Level Member 02blackgpgt's Avatar
    Jan 2009
    Kennesaw, GA
    heres a link from pfyc on how to change the thermostat. as far as the rest, i have no clue lol im sure someone can step in and help you out.
    Thermostat Install
    if it wasnt an automatic front wheel drive four door grandmas car it would be really nice
    Mods?? What the f#ck is a mod??
  5. #5 Re: 97 Grand Prix GT ?'s <----New Guy
    Nov 2008
    conn
    start by checking the wiring and all ground wires,buy a can of electronic cleaner and pull the connections and spray them,i see this alot on larger equipment i work on
  6. #6 Re: 97 Grand Prix GT ?'s <----New Guy
    Scottdale, PA
    Quote Originally Posted by 02blackgpgt View Post
    Thermostat Install
    Thanks for the step by step. Will try that after i get back from taking my girls to Idlewild. As for the other issues i think i know the problem for the ABS and TCC Stuff going to check it this monday.
  7. #7 Re: 97 Grand Prix GT ?'s <----New Guy
    Donating Users chico's Avatar
    First with your cooling problem I would say install a 180deg. thermostat and flush your cooling system ,with your other problem check the connection behind the wheel and dry it out and put a little dab of die electric grease in the connection ,it is quite common on these cars and if the connection not your problem you need to replace the hub .Chico.
    04 gto stock,97 GPGT l-36 block diamond pistons ,l-32 rods ,custom comp cam grind,HS 1-7 RR, p&p heads, SS IC,SS M-90 3.5" ,4t60eHD,from Gonzales TX.
  8. #8 Re: 97 Grand Prix GT ?'s <----New Guy
    Scottdale, PA
    Quote Originally Posted by chico View Post
    Got the main problems with Tstat and the other error lights( wound up being a wheel speed sensor not being clipped up on where it should have been.) but i am still having a problem with a code PO441 which is something to do with this :
    EVAP Emission Control System Purge Flow Fault
    but i have no idea what to do. ?
  9. #9 Re: 97 Grand Prix GT ?'s <----New Guy
    The EVAP is the black canister towards the back of motor...it is in your vacuum line system. Try swapping those out or checking for a vacuum leak around it...might help that too.
  1. t.p.s. 06 grand prix
    By beast3300 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-11-2008, 09:25 PM
  2. New Guy with '04 Grand Prix GTP
    By NSUstud in forum Introductions/Noob Questions
    Last Post: 10-01-2008, 07:44 AM
  3. Should i mod my Grand Prix?
    By Tyler_06 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-16-2008, 09:53 AM
  4. about the grand prix
    By Wadeb79 in forum Off Topic Discussion
    Last Post: 03-24-2008, 11:03 PM
