Thread: Using Series III A/C Compressor on a Series II
Results 1 to 8 of 8
  1. #1 Using Series III A/C Compressor on a Series II
    SE Level Member Rolling Thunder's Avatar
    Jan 2009
    College Station, TX
    I'm doing an engine swap into a Fiero with a 3800 SC III from a 2004 Grand Prix. I'm converting the engine to Series II electronics and throttle body for my application.
    I heard that "2004 GTP A/C compressor is a variable displacement type. As such it needs no cycling switch and is under PCM control." So, will the Series III A/C compressor work with the Series II electronics?
  2. #2 Re: Using Series III A/C Compressor on a Series II
    Banned - Busted For Scamming
    Feb 2009
    series 2 compressors are the same, they have an internal bypass valve. the computer does not cycle the clutch, just turns it on when you hit the a/c and off when you dont.
  3. #3 Re: Using Series III A/C Compressor on a Series II
    Jan 2009
    College Station, TX
    So you're saying that it is not computer controlled, it automatically does it's thing.
    Do Grand Prix's have a pressure switch?
  4. #4 Re: Using Series III A/C Compressor on a Series II
    Feb 2009
    yes they use pressure switches, high and low still, but that is only to tell the computer if its allowed to kick on the compressor, and if something is wrong and the pressure is too high, it will kick it out. Otherwise, its internally regulated. Its a V5 compressor, if you want to read more on it. GM has been using them for years.
  5. #5 Re: Using Series III A/C Compressor on a Series II
    Jan 2009
    College Station, TX
    Ok, so now I know exactly what conversion line I need. This is good.
    On the GP, is the PCM directly connected to the pressure switch? To the compressor? What do the A/C controls on the console connect to?
  6. #6 Re: Using Series III A/C Compressor on a Series II
    Feb 2009
    Ok, just read and to correct myself its not a V5, its a cvc, but same thing, does NOT cycle. The computer uses the input from the a/c control center along with the pressure switches to decide whether to kick on the a/c clutch or not.
  7. #7 Re: Using Series III A/C Compressor on a Series II
    Jan 2009
    College Station, TX
    I hope my A/C controls are compatible with the PCM. I'll have to go to the Fiero forums for that. Thanks for the help.
  8. #8 Re: Using Series III A/C Compressor on a Series II
    Feb 2009
    no problem. there is the other option, just bypass the computer all together and run your own wiring
  1. 3800 Series II MPG?
    By PsychoGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2009, 12:40 AM
  2. How can i get cheap hp out of an 02 firebird 3.8 series 2?
    By firebird92 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-13-2009, 01:54 PM
  3. Series 1 2 or 3?
    By ratnick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-04-2009, 08:08 PM
  4. 3.8 series II sc blows smoke with rev
    By GTX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-16-2008, 01:09 PM
  5. Autometer Z series are fogging up
    By 99prixgt in forum Off Topic Discussion
    Last Post: 09-30-2008, 06:16 AM
