Thread: Rockers or a cam?
Results 1 to 20 of 40
  1. #1 Rockers or a cam?
    GT Level Member SleeperGS's Avatar
    Dec 2010
    Cincinnati, Ohio
    Ok, I know 90% of people would probably say get a cam, but I have a chance to get a set of Yella Terra RR's for a 100 bucks NIB. My car is running in the low 14's.....bout' 14.2. Here are some questions that you FINE people have better knowledge and understanding to answer better than I. I want only (I say that like its easy without the $$$) to get to about 13.5 or maybe 13.2. It is a DD that goes 80 round trip almost daily. questions are.
    1.) rocker or cam? rockers way easier as it relates to install and cheaper too.
    2.)Will have a ported TB in the next two weeks regardless of which way i go; rockers or a cam.
    3.) currently have a 3.4 pulley. Can I drop to a 3.25 with the rockers or cam either way. I'm going to have to car scanned before and after to detect KR. I have 103's but I think they are to cold, going 104's unless you think I should stay with the 103's with the soon to be TB ported and the cam or rockers.
    4.) Im leaning toward rockers, if I do this, what elese should I replace while im there other than the valve cover gaskets and the rockers? Springs?
    5.) Can I flip the dog bones even though I have poly mounts?
    6.) Why do we park on 'driveways' and drive on 'Parkways'?
    7.) Will rockers and the TB get me to mid 13's? I know nobody can say for sure, just looking for insight.
    Thanks again for the thoughts and for all my aggrevating questions.
    Kevin
  2. #2 Re: Rockers or a cam?
    Dec 2010
    Cincinnati, Ohio
    Oh yeah, have a 3800 performance tune on it, will I have to get that changed?
  3. #3 Re: Rockers or a cam?
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    thats a big ask for even a cam, I don't think you will get anywhere near that with just rockers, so that being said go with a cam. Plus cam is just so much cooler but you would still see good gains out of the rockers.
    You say your having the car scanned for kr...are you having it tuned? A good tune will be key in getting good gains.
    I also see your located in ohio I might suggest looking in to having your rockers or cam installed at prj. If not installed there I would still reccomend getting paul to tune it for you
    Welcome to PRJ.Performance
  4. #4 Re: Rockers or a cam?
    Donating Users
    South Deerfield, MA
    If money and time are not an issue, then I would say cam, but at that price, I would jump on the rockers and add an intercooler later on. A good tune and driver mod are key to getting the times you want.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  5. #5 Re: Rockers or a cam?
    Dec 2010
    Cincinnati, Ohio
    I already have a 3800 performance tune, I want a real tune though, one customized for my car. I would hope that the ported TB and rockers would at least put me in the 13's.
  6. #6 Re: Rockers or a cam?
    Charles City, IA
    You should be hitting 13s with the 3.4 set up and a good tune. If they are stock ratio rockers I will give ya 125 for them right meow.
    SMGPFC Two Nipple General
  7. #7 Re: Rockers or a cam?
    Dec 2010
    Cincinnati, Ohio
    You said meow.....he he he
  8. #8 Re: Rockers or a cam?
    Dec 2010
    Cincinnati, Ohio
    I haven taken them off yet, but it will be in the neext few days. I cannot get in the 13's with the way im set up right now. Im launching good, car runs like a top, decent mods, 3800 performance tune....just can get in the 13's. Its a travesty meow...
  9. #9 Re: Rockers or a cam?
    Waukesha, WI
    whats your DA ?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  10. #10 Re: Rockers or a cam?
    Dec 2010
    Cincinnati, Ohio
    DA= dollar amount?
  11. #11 Re: Rockers or a cam?
    Dec 2010
    Cincinnati, Ohio
    or DA, cause im a dumb ass and dont know what DA is???LOL thats funny.
  12. #12 Re: Rockers or a cam?
    Dec 2010
    Cincinnati, Ohio
    With the rockers, if its scanned, can I go to the 3.3 or a 3.25 pulley? Like my pistons un-chipped, hence the reason for said question
  13. #13 Re: Rockers or a cam?
    I vote in-car wideband tune.
    You should be able to pull of 13's with your setup.
  14. #14 Re: Rockers or a cam?
    Dec 2010
    Cincinnati, Ohio
    meaning without the rockers and a pulley, just the way its sits now?
  15. #15 Re: Rockers or a cam?
    Grand Island, Nebraska
    Have to remember that regals are a bit heavier. Do you know what ratio the YT rockers are? For $100 i would definitely jump on them since a cam will cost at least 5x more. That and an in-car tune should get you close to where you want to be.
    DA= density altitude. like how high above sea level you are. It has a big impact on 1/4 times.
  16. #16 Re: Rockers or a cam?
    Dec 2010
    Cincinnati, Ohio
    Cincinnati is 540 feet above seal level
  17. #17 Re: Rockers or a cam?
    Dec 2010
    Cincinnati, Ohio
    And yes, the Regal is 124lbs heavier. Curb weight acc'd to Edmunds.com
  18. #18 Re: Rockers or a cam?
    Thats 0.124 seconds.
    You're more than that far away from your goal.
    Jump on the rockers if they're high ratio.
    And an in car tune and you should be good.
  19. #19 Re: Rockers or a cam?
    Dec 2010
    Cincinnati, Ohio
    Gotta find someone that can do the tune and then I will jump on it.
  20. #20 Re: Rockers or a cam?
    Minnesota
    Whats the ratio?!
  1. rockers in a 06 L32
    By reallyfast1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2011, 09:38 AM
  2. 1.9 rockers
    By wking2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2010, 07:18 PM
