Thread: 98 GTP tranny problems
Results 1 to 6 of 6
  1. #1 98 GTP tranny problems
    GT Level Member pontiacGTP123's Avatar
    stanford Ky
    I installed a 99 DHP in my 98 GTP it seems to run fine, great power. Ive had it in for about a week now no problems until it got cold last night and this morning. I has been shifting so smooth but last night it shifted really firm and quick. This morning I started it and let it warm up about 7 minutes before I left. It shifted smooth again for about 10 minuted but then started shifting really firm and quik again. Also when It goes into 4th gear it fills like I ran over a bump in the road as its shifting. kind of like a suddem mild jerk. Could It be the temperature changing from hot to cold? Its was around 45-55 degrees between last and this morning. Is this normal?
    05 gtp- k&n open cone, intense tune, cat delete
    99 gtp- sold
    97 chevy 2500 diesel- heath turbo master, custom cai, 4" straight exhaust
    70 chevy c10- 6.0 swapped, still a project
  2. #2 Re: 98 GTP tranny problems
    Ummm...could be the 4th clutch taking a crap on you. They are kinda known to do that but you don't have hardly any mods idk. Plus you mean firm and quick...the DHP PCM cranks up the tranny line pressure so it does that. Try turning OFF Performance Shift.
  3. #3 Re: 98 GTP tranny problems
    stanford Ky
    Its been off when it does it. How hard is it to replace the clutch? I guess I would have to remove the tranny to do so. Also would a shift kit help out?
    99 gtp- sold
  4. #4 Re: 98 GTP tranny problems
    Quote Originally Posted by pontiacGTP123 View Post
    You know anything about transmissions? Ask Dave...trannyman95 about replacing that 4th Clutch...I think if memory serves me you basically gotta pull the entire thing apart...EVERY...LITTLE...PART.
  5. #5 Re: 98 GTP tranny problems
    Barksdale AFB, LA
    Not for the fourth clutches. Just gotta take the side cover off. It's a bit of a job just to get that far, though. The fourth clutches are actually recessed in the side cover itself.
    2009 Subaru Impreza WRX STI
  6. #6 Re: 98 GTP tranny problems
    SE Level Member 98SilvermistGTP's Avatar
    Nov 2008
    Eastern KY
    I have noticed my 4th gear shift kinda thumps. It done that before the rebuild and still does it after. I have a DHP as well, but it is a 98 PCM in a 98 car, I dont think the fact of it being a different year would have anything to do with it in your case. I have an Overkill PCM on the way, so I will get to see if there is any improvement.
    The fourth gear clutch set and chain is accessible with out pulling the tranny, but you have to get to the side cover and there are several things you will need to remove. It is not a job for anyone that does not have some decent mechanical skills.
  1. NEW GUY NEW Problems!?
    By 06GPNA3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2009, 11:43 PM
  2. tranny problems
    By krippled in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-04-2009, 01:35 PM
  3. New Tranny Problems..
    By NMillis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-30-2008, 06:24 PM
  4. TC lockup/unlock problems? tranny rebuild ?'s trannyman step in!
    By kyle99gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-08-2008, 01:24 PM
  5. Sudden tranny problems...
    By Blinksy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-05-2008, 12:16 AM
