Thread: Poly mounts...knocking sound
Results 1 to 5 of 5
  1. #1 Poly mounts...knocking sound
    Donating Users
    Plainfield, IL
    hey guys ever since my poly mounts install ive been noticing when i hit bumps its sounds like a quiet knock sounds like the mounts because when i come to a stop it makes that noise but only once as if the motor shifted the and pushed the mount forward then back....does anybody else hear this?
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: Poly mounts...knocking sound
  3. #3 Re: Poly mounts...knocking sound
    my buddy has a solid motor, tranny, and poly uppers...his creaks a bit when its cold and he puts it into gear but thats it.
  4. #4 Re: Poly mounts...knocking sound
    GT Level Member Preotic's Avatar
    Missoula, MT
    Check to make sure you tighten the bolts good on both ends of the dogbones. If that's not it then perhaps you installed them wrong(hard to do but not impossible) or maybe the round bushings are shot. If they are creaking you can use asssebly lube or grease to quiet them. Mine have never made a clunk or knock but they did creak and some grease solved that.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  5. #5 Re: Poly mounts...knocking sound
    Donating Users
    Plainfield, IL
    they are making a clunk noise i think it may be the round bushings....
  1. FALSE KR/ poly mounts
    Last Post: 05-10-2016, 03:30 PM
  2. Go poly mounts!!!
    Last Post: 04-22-2009, 03:02 PM
  3. Poly Motor Mounts
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2008, 09:33 PM
  4. Poly Mid mounts 4 GMPP Sways
    By black.gtp in forum Brakes/Suspension/Chassis
    Last Post: 05-02-2008, 07:29 PM
