Thread: idle...HELPPP
Results 1 to 11 of 11
  1. #1 idle...HELPPP
    Donating Users
    Plainfield, IL
    ok guys i noticed my car vibrating like crazy at stop lights...first i thought it was a dp rubbing issue....but no i watched today and everytime im slowing down as im almost stoppped my rpms dip down to about 450 and they keep dipping slightly at the light from 850-650 and the dipping is causing the vibration almost like it keeps coming close to a stall....what would cause this i know i got a vacuum leak because my ltft's are +16.4 any ideas if i brake torque and raise the idle myself the vibrations go away...so i wanna fix it lemme know...
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: idle...
    Find the vacuum leak. Then...if that don't do it sounds kinda like a CPS...
  3. #3 Re: idle...
    Donating Users
    Plainfield, IL
    canister purge solenoid right? i did break that during the 1 piece pacesetter install lol i glued that shyt back together i bet some glue bloked it haha would you def say thats it then? will that fix my trims??
  4. #4 Re: idle...
    Jan 2009
    hammond, IN
    mine is doing the same but sometimes my car just dies outa nd starts then dies right back out but when i start it and punch it for about 15 sec. it just goes back to regular idle like nothing even happened. i just changed my MAF sensor and crak shaft sensor also and did a full tune up on it. any help?
    (sold)GTP-Intense pcm,zzp 3.4 pulley, colder plugs, zzp dp, magnaflow converter, k&n intake, autometer gauges, zzp motor mounts, u bend delete, res delete, 180 stat
    1997 lt1 formula- to many mods to list.
  5. #5 Re: idle...HELPPP
    Donating Users
    Plainfield, IL
    bumpity...
  6. #6 Re: idle...HELPPP
    get a can of carb spray and spray it on the motor on the suspected spots. if the idle changes when you spray it at an area then youve found your vacuum leak.
  7. #7 Re: idle...HELPPP
    Donating Users
    Plainfield, IL
    ok sweet ignore my other post asking how in vac leaks haha
  8. #8 Re: idle...HELPPP
    TDCRacing
    Guest
    I was like where in the heck did my post go! I did not realize this was a different thread until just now lol
  9. #9 Re: idle...HELPPP
    you should definately try and consolidate your threads. change the title and ask more/different questions if need be. no reason for you to have 3-4 threads on the first page all created by you.
  10. #10 Re: idle...HELPPP
    Donating Users
    Plainfield, IL
    yeah i was noticing that my bad peeps
  11. #11 Re: idle...HELPPP
    Jan 2009
    hammond, IN
    anyone know anything about what mine could be? lol
  1. idle issues
    By gnjim in forum General Tech Discussion
    Last Post: 03-06-2012, 01:46 PM
  2. car died at idle
    By b00stinGTX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2009, 05:59 PM
  3. '97 GTP, rough idle
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 01:14 AM
  4. Almost rough idle
    By DesQ27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-01-2009, 08:31 PM
  5. Rough Idle
    By Red_GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 02:29 PM
