Thread: Coolant Loss, intake Gasket or Intake Itself???
Results 1 to 3 of 3
  1. #1 Coolant Loss, intake Gasket or Intake Itself???
    Apr 2009
    SE Kansas
    I have a '98 Grand Prix w/ the non supercharged 3800. I'm loosing water, and when i changed the oil (for the first time, just go the car) it was damn near the consistency of water, so i would assume the coolant is leaking internally. I pulled a big grease ball out from under the radiator cap, not sure if its from oil or is this from the dex-cool that was in it?
    My question is, which is it most likely, just the intake gasket, or the intake itself?? There is no external leakage around the intake. I do have a leaking radiator which there goes some of the water, but there was definitely alot of water in the oil before i changed it. Any clues would be appreciated.
  2. #2 Re: Coolant Loss, intake Gasket or Intake Itself???
    Barksdale AFB, LA
    The gaskets can (and often do) leak internally with no external signs. I have only once heard of the intake itself leaking, but that was a unique case. Your intake gaskets are pretty much gone. Stop driving the car before you spin a bearing (since coolant is in your oil) and get them changed. It's not a hard job to do.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Coolant Loss, intake Gasket or Intake Itself???
    Apr 2009
    SE Kansas
    thanks, have to come up w/ a gasket set, radiator, and change the oil again, hopefully that will fix all its issues. I guess i should get the cooling system flushed? Wonder what that costs..
  1. Replies: 84
    Last Post: 09-09-2015, 08:10 PM
  2. Intake Manifold Gasket/seal
    By ssm90GT in forum General Tech Discussion
    Last Post: 12-12-2009, 03:06 AM
  3. Intake gasket
    By mjt in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-12-2009, 12:28 AM
  4. Intake Gasket Replacement
    By wicked50 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2009, 06:21 PM
  5. Intake manifold gasket
    By rudyram118 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2008, 09:38 PM
