Thread: 2000 gp ac compressor replacement
Results 1 to 6 of 6
  1. #1 2000 gp ac compressor replacement
    Apr 2009
    Waxhaw, NC
    I've done work like this before, but it was on a 1997 Suburban or 1969 Custom S. What else do I need to remove to replace the AC compressor on my 2000 GP? It look slike the radiator will have to come out just to get access to the refrigerant lines, but I may be mistaken. Any guidance would be greatly appreciated!
  2. #2 Re: 2000 gp ac compressor replacement
    TDCRacing
    Guest
    Unbolt the 1 bolt that holds both of the lines on and take off the remaining 3 bolts off that hold the compresor onto the mounting bracket. Thats it.
    Welcome to the community.
  3. #3 Re: 2000 gp ac compressor replacement
    Apr 2009
    Waxhaw, NC
    Thank you TDR Racing for the reply, sounds easy enough. I'm just used to working on cars more than 40 years old, not these front wheel drive smog free machines! Thanks again!
  4. #4 Re: 2000 gp ac compressor replacement
    SE Level Member Joe8389's Avatar
    Greeneville, TN
    Will this same procedure work on a '97 GP?
  5. #5 Re: 2000 gp ac compressor replacement
    TDCRacing
    Guest
    Yes.
  6. #6 Re: 2000 gp ac compressor replacement
    St. Louis Mo.
    Moved to the correct location.
    James Shafer
    St. Louis MO
  1. AC Compressor
    By Willthesage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2009, 02:56 PM
  2. How big of a compressor should I get?
    By FuglyGTP in forum Off Topic Discussion
    Last Post: 03-06-2009, 08:18 PM
  3. Bad AC compressor??
    By HOPPY in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2008, 07:06 PM
  4. AC Compressor replacement????
    By 03renegade800 in forum Off Topic Discussion
    Last Post: 06-26-2008, 03:18 AM
