Thread: Boost Controller
Results 1 to 20 of 37
  1. #1 Re: Boost Controller
    Banned - Busted For Scamming
    Feb 2009
    girl at school has a redline, turned it on all the time with a tech 2. the svt lightning at school is not on all the time from the factory either. the supercharged LSJ's intercooler sucks anyways, by the 3rd pass on the dyno it was completely ineffective, due to its fmhe being only 3/4" thick. i will be doing this when i throw on my 3.0 pulley with my phenolic ic core. im having the solenoid to the switch that controls my pump on/off, when i hit the ic on button, the solenoid will block off boost to the bottom of the bbv diaphragm, giving full boost. when its de energized, it will allow a metered amount of boost to go to the bottom of the diaphragm, keeping boost around 8 psi.
  2. #2 Re: Boost Controller
    Must be a truck thing them because my buddy's '03 AND '04 Cobra (yes, he has two of them) both run all the time...one is TT'ed and the other is stock with a K&N Cone.
  3. #3 Re: Boost Controller
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    You cannot base the effectiveness of an intercooler off of it sitting stationary on a dyno...the heat exchanger works off of air passing over it. Pointing a fan at it is not going to be the same as air moving over it down the street or track. Thickness is only one small part of the equation.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  1. Electronic boost controller
    By TDCRacing in forum Turbo
    Last Post: 10-28-2009, 11:26 PM
  2. boost??
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 06:59 AM
  3. More boost?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 07-25-2008, 12:33 AM
