Thread: Stuck In Park. Shift Lock Release Doesnt Work.
Results 1 to 20 of 22
  1. #1 Re: Stuck In Park. Shift Lock Release Doesnt Work.
    SE Level Member jmflores1970's Avatar
    Austin
    Hi all! I just had this happen to me today when I got out of work. When I was going to work, some plastic crate pieces were scattered on the highway underpass. I thought I had gone around them all, but I drove over one piece and felt it hit the bottom of my car. I kept driving normally, got to work and forgot about it. When I was going home, the shifter was stuck in Park. I remembered driving over those plastic crate pieces and figured that's what caused it. I've never had any trouble with this 'til today, and my car is almost 11 years old. What's weird is that when I try to shift out of Park, I hear something clicking behind my instrument panel, so yeah, sounds like an eletrical issue. I had never used the Shift Release button before, so I was not sure how I was going to get home. I finally popped up the little cover, pushed in with my key and felt a small lever go down. That released the shifter and I can drive normally now. I just need to push in with the key everytime to get it out of Park 'til I can get it fixed. At least for now, my can't can't be easily stolen. LOL
  2. #2 Re: Stuck In Park. Shift Lock Release Doesnt Work.
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    I've got a new problem that I haven't read about. I sometimes cannot get my sifter out of park. Tonight I am going to check the wires on the bottom of the shifter. My problem is when the key is not in the ignition The car wont go out of park unless you use the manual release. I am fine with this the new problem is when I put the key in and start it or put it in the run position I am able to shift to any gear without touching the brake or the release. I really don't know where to start fixing this other then the wires. If I could get some pointers that would be awesome.
    silver 2003 Grand Prix GT List is on it's way to be updated
  3. #3 Re: Stuck In Park. Shift Lock Release Doesnt Work.
    Austin
    Thanks to y'all, I knew what to look for on YouTube to fix this. I found this video posted by Turbo231. In my case, it was a red wire which got cut off from the quick disconnect clip. It was the only loose wire and only one connecter was missing a wire. I just stripped the wire with scissors and pushed it back in for now. Issue resolved. One day when I have the space & tools, I'll fix it the right way by soldering it.
  1. Key stuck in ignition lock cylinder
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 01-17-2019, 10:47 AM
  2. Won't Shift Out of Park (sometimes)... Ignition Switch?
    By GTFiske in forum General Tech Discussion
    Last Post: 01-12-2011, 12:53 PM
  3. Car won't move out of park and key stuck in ignition
    By DanGTP in forum General Tech Discussion
    Last Post: 10-09-2010, 03:46 PM
  4. Possible reason heat doesnt work? Need opinions.
    By m0ng00se in forum General Tech Discussion
    Last Post: 11-23-2008, 12:57 PM
  5. Heating Doesnt Work After Engine Replacement
    By m0ng00se in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-16-2008, 07:06 PM
