Thread: No communication through OBD connector
Results 1 to 13 of 13
  1. #1 No communication through OBD connector
    Apr 2009
    Annapolis, MD
    My 00 gp gt has been running really strange. The gas mileage is very poor maybe 9.5mpg or so. There is power in pin 9 and the ground pins 405 appear good. There also is a slight knock at startup but the biggest issue is the lack of communication tru the OBD. Has anyone else had this problem or can give me some insight on what I should do?
  2. #2 Re: No communication through OBD connector
    Jan 1970
    Maquoketa, Iowa
    What are using to hook up to the OBD2?
  3. #3 Re: No communication through OBD connector
    Apr 2009
    Annapolis, MD
    A genesis 3.0 and a snap on was used and it failed to communicate with either.
  4. #4 Re: No communication through OBD connector
    St. Louis Mo.
    Moved to a more correct area.
    James Shafer
    St. Louis MO
  5. #5 Re: No communication through OBD connector
    Apr 2009
    Annapolis, MD
    Anyone?
  6. #6 Re: No communication through OBD connector
    Banned - Busted For Scamming
    Feb 2009
    does it power up the obd2 scanner? or just not communicate?
  7. #7 Re: No communication through OBD connector
    Apr 2009
    Annapolis, MD
    Yes it senses the cable and machine and that the key is turned on. The scanner said no communication check fuses, yet all the lights on the dash are working fine.
  8. #8 Re: No communication through OBD connector
    Donating Users
    Plainfield, IL
    horn fuse! try that gm wired they're obd II in with the horn fuse see if your horn works...i had this same problem once in another pontiac...stupid gm people decided to wire shyt retarted lemme know if that works
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  9. #9 Re: No communication through OBD connector
    Apr 2009
    Annapolis, MD
    I just tried my horn n it works fine so idk
  10. #10 Re: No communication through OBD connector
    Apr 2009
    methuen
    try replacing you cigarette lighter fuse, that also runs ob2 port. Make sure next time you plug in your scanner first then turn the ignition key on, if not it may blow the fuse again. hopefully that is your problem man.
  11. #11 Re: No communication through OBD connector
    Feb 2009
    yea mine was cigarette lighter fuse lol but it wouldnt power up the scanner for me, so thats how i knew.
  12. #12 Re: No communication through OBD connector
    Apr 2009
    Annapolis, MD
    Both my cigarette lighters work so that couldnt be it. I think it may b a wire short somewhere. Now the problem is i need to find it in the miles of different wires.
  13. #13 Re: No communication through OBD connector
    Apr 2009
    Annapolis, MD
    So i went thru emissions today and obviously it didnt communicate so it didnt pass. But they told me it most likely has something to do with the wiring in the alpine stereo i have in it. But idk anything abt the wiring where should I start? ground wire?
  1. PCM Connector Schematics
    By Reptile in forum General Tech Discussion
    Last Post: 01-14-2011, 06:28 PM
  2. Where does this connector go?
    By boogsey in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-21-2008, 09:34 AM
  3. iPod connector
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 07-31-2008, 06:35 PM
  4. DIC connector pic
    By Toasty in forum General Tech Discussion
    Last Post: 05-30-2008, 05:17 AM
  5. Where does this connector go?
    By alacran in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2008, 07:19 PM
