if you have never taken off the bolt in the crank, there is an easy way... take a 15/16 1/2 inch drive socket and ratchet and put it on the crank bolt and rest it on the cradle facing forward in the ratchet reverse mode, then disable the ignition system, and bump over the engine with the starter.
A very respected member here did me a write up on removing the balancer, and this was at the top of his "things not to do" list.
It took me a while to impact it out, but it did finally come out. I used three Grade 8 bolts like TDC suggested to you with some washers. If I had to do it again I would get Grade 8 washers or triple stack the washers since they got pretty bent up. Make sure all three are threaded in evenly so it pulls evenly.
Oh, and use a 1/4" drive deep socket as a spacer to protect the crank threads. Small enough to go in all the way, but large enough to not play.
