Thread: Engine Build
Results 1 to 20 of 35
  1. #1 Engine Build
    Northeast Ohio
    ok people im currently into a 3800 build this is what im thinking so far please chime in or suggest anything......but meth,alcohol, and e85 are out of the question
    starting with a l26
    gen v and lim both ported
    l67 heads rebuilt w #130 valve spring, port and polished
    zzp xp cam or intense x1 with rockers
    comp oe-r lifters
    double roller timing chain
    headers
    would run a 3.4 pulley
    180 t stat
    down pipe
    catback exhaust
    later down the road
    full ic
    42lb injectors
    using 3.0-2.8 puller
    once fully done hoping for close to 450 CHP
    again im open to all suggestions and or comments im looking to have a mean machine yet stil can be a daily driver
    The Boss Iceman6669's Avatar
    Jun 2011
    Dude if u are doing all that work and running a double roller timing chain I would go with the XPz cam... Just .02.
    2011 F-150 Yote powered
  3. #3 Re: Engine Build
    Looks ok.
    You might get mid to high 300's CHP, no way you'll ever hit 450 without a turbo.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Any cam with higher rate valve springs should run a double roller.....I've seen a few single chains and dampener on after market springs....its not pretty. He would be out of his fuking mind to run 130 springs on a single chain. Plus he probably wants the drive ability of the XP
    OP, build looks really good man! With that setup u would b okay to start with about a 3.25 pulley, imo
    Sent using my bionic thumbs from my sweet DROID Razr Maxx
    For all your 3800 needs:
  5. #5 Re: Engine Build
    Northeast Ohio
    Looks ok.
    from what im readin with the ic and all that noise it should be around 400-450chp
  6. #6 Re: Engine Build
    No mention of a trans "build"
    Jun 2011
    A 3.4 setup with an xp cam is good for roughly 300-320 whp... So FFDP is prolly right, u will most likely be high 300's. But I agree with cop, you could start out with a smaller pulley if u are running a cam. But remember to scan.
    Ohio
    Good luck with that l26 bottom end. And it's higher compression as well. He can stay with a 3.4. Hell I would leave to a 3.8 until he goes intercooled then drop the pulley.
    Orange County, NY
    He has l67 heads.....
    Ohio
    Your point?
  11. #11 Re: Engine Build
    Northeast Ohio
    Quote Originally Posted by 99pgpgt View Post
    y would you be worried bout the bottom end?
  12. #12 Re: Engine Build
    Pretty sure Ive seen many times now its the L26 rod bolts that fail not the actual rods failing. Go buy some ARP ones. I believe there is a thread on GPONA.com about this if its not here somewhere also.
  13. #13 Re: Engine Build
    Troy OH
    i feel like you're gonna run your injectors static quick. and the headers will usually replace the downpipe portion of the exhaust, as well as the cat, so keep that in mind when you buy. be ready to put a bigger pulley on that too, the genV is a lot more efficient and you're still on a high compression block. a modular pulley hub makes life easy. other than that, looks like a solid build and i wish you the best of luck
  14. #14 Re: Engine Build
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    L26's throw rods sometimes, but this is primarily with Turbo or xpz 6600 ron shift point builds. Nothing to worry about with your goals.
    An XP/s1x setup on a 3.4 is not gonna make 320whp. You might get near 300, but even with high compression and a Gen V, I doubt it.
    Ditch the double roller and the 130# springs. Get cheap 90# springs. They will make more power, and wont tear sh1t up in your valvetrain. Ls6 springs can take you to 6500rpm without any issues. And there's no need to shift higher with an XP, s1x. Put the saved money towards those 42# injectors and a tune.
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
    Ohio
    Or 105s and a stock chain. More forgiving on the chain and dampener
  16. #16 Re: Engine Build
    Northeast Ohio
    ok thanks for the points......what else could i do to hit some higher numbers?
  17. #17 Re: Engine Build
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    take the turbo build route and get your big numbers. To get 450 CHP off a SC will be one hell of a build. you want those big numbers, go turbo
  18. #18 Re: Engine Build
    Nov 2009
    Michigan
    ^Agreed. Go Turbo. Granted, there are m90 bulids in the 10's. But its rare and triple the effort.
    I'm hoping to see11's soon but I'm not expecting it. After this, I'm gonna have to get realty creative
  19. #19 Re: Engine Build
    Northeast Ohio
    turbo is way too much money tho i mean for the set-up posted above a turbo is close to 3 times that money
  20. #20 Re: Engine Build
    new britain, ct
    gotta pay to play. you want 400-450 CHP? you go turbo and build your own turbo kit and get a built transmission. itll cost more in the long run to get that much power out of a supercharged car.
    07 Black GXP.
  1. engine build...
    By gtpsleeper in forum General Grand Prix Discussion
    Last Post: 02-11-2012, 10:14 PM
  2. Engine Re-Build w/Z7 Kit
    By ARFF22 in forum Turbo
    Last Post: 02-13-2011, 06:22 PM
  3. engine build on a budget....
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2009, 10:16 PM
  4. Need advice on engine build.
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 06:40 PM
  5. Engine Build
    By ChrisGTT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-02-2008, 04:18 AM
