That vac leak could be the cause of your low power. Get that fixed and see what you get. Also may want to clean the MAF and then reset the ECU (disconnect the battery for 30 min or so). Then take it for a drive to let it relearn everything.
Thanks I did replace maf sensor last month. 137.00 +80.00 core charge, maf cleaner worked for a bit.
I may have only had battery disconected for 15-20 minutes, I will disconect tonight, no at work today and set for while.
I have to got to a dealer and get this T/hose set up and hope that is the vac leak.
also need the fuel sending unit cause my gauge always jumps to full when it is low.
Thanks again bud
If you suspect those hoses to be a vac leak give em a spray with some carb cleaner while idling and see if you notice the engine change tone. Not sure I suggested that or not yet.
Track down any vac leaks before you jump into the compression test. From what I have read it really doesn't sound like you are low on any cylinders. With those MPG's on the highway I would think it'd be lower with a compression leak. But I've been wrong before.
When I spray hoses,intake,tb,injectors, w/carb cleaner no change in tone. doesn't do it all the time but sometimes at stop light engine will vibrate car a little like there's a vac leak, thats why I suspect a vac leak. I sprayed every vac hose connection(nothing). i did reset computer, left bat unpluged 40 minutes or so last night see if power is better after 35 40 miles put on.
