Sounds like you finally are getting the red dragon back on the road.
If you need any diagrams for your car, let me know year/model and email address to send it to.
Thanks for all the files very helpfull, just got heads and parts back today, but machinist took out all bolts that helped me I dentify front and rear head and where the brackets and everything bolted on, I don't know which exhaust bolt was a bolt that fastens exhaust and had a bracket or something bolted on to it.
I would send pictures but daughter forgot the cable to download pics.
Mario
Are those the aluminum LIM gaskets? Cause from the pic they look black, like the plastic ones.
Also, don't forget to put a dab of RTV in all four corners of the end seals for the LIM to block gaskets. I put some under the gasket, and then on top before seating the LIM. Never leaked again.
shoot I didn't put any on top just across the bottom, suppose I better do that now, dam I wish you caught me last night, been fastened since with thread lock, Thanks a lot though probbobly saved a big head ache down the road, rather pop of and give it a good rtv hit now then have to tare everything apart later, and yes sir they are the plastic gaskets (dam another thing I forgot about).
I posted 7 minutes after your post that showed "Progress ready for intake install", where you still had the LIM off. Figured you'd see it in time.
I'm not saying that it will leak if you only sealed the bottom part, just that I've always been told to put some at just the corners on top and bottom of those end seals where the seal meets the head and LIM. As long as the RTV is thick enough on the bottom part you might be ok, your call there.
Although I wouldn't reinstall plastic LIM gaskets at all. There is a reason GM came up with the updated Alum. ones. I am actually surprised that they still make the plastic version after all the motors that have had this issue.
