Thread: overheating - loss of power
Results 1 to 20 of 77
  1. #1 Re: overheating - loss of power
    SE Level Member ASCStinger's Avatar
    Jan 2009
    Rochester, NY
    check compression? you can also try pressure testing the cooling system, but I'll bet your lim gasket's leaking at the least. The coolant can get into the cylinders and foul up the plugs, or even hydrolock them in severe cases. Also, any oil/coolant burnt will foul the O2 sensors and plug up the cat, which would also cause the car to run like crap.
  2. #2 Re: overheating - loss of power
    Aug 2008
    Seattle, WA.
    Quote Originally Posted by ASCStinger View Post
    Thanks bud,
    I got the scaneer, and it read as follows:
    1 of 2 -
    code P0303, and undernieth code it says Cyldinder #3 Misfire
    2 of 2- (Same)
    code P0303, and undernieth code it says Cyldinder #3 Misfire,
    Why did it say the same code twice? Is it because of two different problems that caused the P0303 Code
    Thanks
    1997 Grand Prix SE 3800 series 2
    No mods yet.
  1. Random smoke and power loss.
    By bradford82 in forum General Tech Discussion
    Last Post: 01-14-2009, 08:15 PM
  2. power loss
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2008, 11:12 PM
  3. HELP!! overheating
    By sciontc1011 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:55 PM
  4. overheating
    By zach_gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-09-2008, 10:18 PM
  5. Electrical Power Loss
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 06-17-2008, 07:40 PM
