Thread: Which down pipe should I get?
Results 1 to 20 of 21
  1. #1 Re: Which down pipe should I get?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    True, N/A cars probably don't NEED a 3" Downpipe...but is it going to hurt? No.
    False. Exhaust velocity is what gives you the scavenging effect, giving you a lot more low end. Too big and you may gain on the high end, but you end up with no low end to get you there. The exhaust system needs to be balanced, which is why saying that every car should run a 3" DP is just ignorant.
    2001 Buick Regal LS - Almost Stock
  2. #2 Re: Which down pipe should I get?
    Apr 2009
    CT
    Quote Originally Posted by Scimmia View Post
    thank you! Someone who understands and doesn't insist on just throwing the biggest exhaust available at the car.
    An exhaust that doesn't scavenge is a motor that has to work harder. Depending on the type of boost and how much, it still can be a factor.
  3. #3 Re: Which down pipe should I get?
    Quote Originally Posted by Ragefear View Post
    I don't insist on throwing on the largest exhaust available. I understand his side of it. I am just stating that it is all personal preference...up to you whether you want a bigger downpipe or not...the market is there and you can buy it if you like. If you don't want to harm the back pressure of your N/A car then get a 2.5".
    BTW...there was no Boost...we were talking N/A's last time I checked...
    Just wondering...so you're telling me if you were to line up 2 GT GP's one with a 2.5" DP and one with a 3" DP...you're saying the outcome would easily be in the favor of the 2.5" DP'ed GT? I honestly doubt that your velocity claims make THAT much difference. The Torque the 3" DP guy loses from the larger Dp will make it up with less wheelspin. Same concept with a GTP with headers vs. a GTP with PEM's. Go test it and I'll side with you on your theory...
    Some people would like more top end, others want torque. It is based on personal preference anyways IMO.
  1. True Duals with X-pipe on a GP??
    By Uno99 in forum General Tech Discussion
    Last Post: 04-26-2014, 08:31 PM
  2. down pipe and header question
    By iwinagn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2008, 10:57 PM
  3. what Down pipe to get for my N/A 3.8
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2008, 06:14 AM
  4. Drooping tail pipe
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 06-27-2008, 11:12 PM
