Thread: winshield wiper help
Results 1 to 6 of 6
  1. #1 winshield wiper help
    Donating Users RedLedbetter's Avatar
    Feb 2009
    Illinois
    my winshield wiper on the passenger side seems to stick up. at first i thought it was just caught up on the other wiper, but it seems to be that this is the farthest it will go down when i turn my wipers off. anyone know how to fix this?
    here are some pics
    Any help is appreciated
    SPREAD THE JAM
  2. #2 Re: winshield wiper help
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    If you take off the wiper arm you can reinstall it in the proper place. removing it is fairly simple, if it isnt rusted or corroded on the stud. I havent done it on my gp, but have done many othersas I use to work in a body shop, it has a nut on top of the wiper arm at the base, or it will have a little tab under the arm that you should be able to see if you lift the arm all the way up, off your widshield.
  3. #3 Re: winshield wiper help
    Feb 2009
    Illinois
    hmm, i just tried that. i think its a little rusted. ill keep trying
    SPREAD THE JAM
  4. #4 Re: winshield wiper help
    Banned
    Feb 2009
    Wilmington, MA
    sometimes you have to use that clip remover tool, so you can get under the wiper arm and pry it up, be carefull not to crack the windshield.
  5. #5 Re: winshield wiper help
    Feb 2009
    Illinois
    ive tried this but i cant get the wiper arm off. i took of the black cap and then removed the nut at the base of the wiper arm. i tried pulling it but it wouldn't come up. i didnt want to pull to hard incase i would break something, but after i take that nut off do i just pull as hard as i can until the arm comes off?
    SPREAD THE JAM
  6. #6 Re: winshield wiper help
    SE Level Member StreetChariot's Avatar
    Cowtown, OH
    Rock it back and forth using the spring in the arm. Overtime they get stuck to the shaft. I just fixed both my driver and passenger side as they were stuck crossed over the windshield.
    If you grasp the arm and apply slight pressure towards the windshield and away from the windshield repetitively it should come off.
    Be sure to mind your windshield... They are expensive (esp. if you have HUD).
  1. wiper motor
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-08-2011, 01:19 PM
  2. rubber seal around winshield
    By Tyler_06 in forum Visual/Body Modifications
    Last Post: 07-23-2010, 07:04 PM
  3. passenger wiper arm
    By Charged97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2009, 07:55 PM
  4. Where do you buy new wiper arm?
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 06-11-2008, 08:04 PM
  5. Wiper problem again
    By Fish in forum Visual/Body Modifications
    Last Post: 02-01-2008, 03:22 PM
