If you take off the wiper arm you can reinstall it in the proper place. removing it is fairly simple, if it isnt rusted or corroded on the stud. I havent done it on my gp, but have done many othersas I use to work in a body shop, it has a nut on top of the wiper arm at the base, or it will have a little tab under the arm that you should be able to see if you lift the arm all the way up, off your widshield.
