Thread: Cleaning Top end with Water rather than Seafoam
Results 1 to 5 of 5
  1. #1 Cleaning Top end with Water rather than Seafoam
    SE Level Member abuckley1290's Avatar
    Jul 2008
    When i was buying a can of seafoam the guy working there told me he used to do the same thing, but with water. He said it kinda steam cleans the engine..has anyone had any experience with this? is it safe/effective? thanks
  2. #2 Re: Cleaning Top end with Water rather than Seafoam
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    WHAT?? UM NO. the point of seafoam is to take out water... putting water into your engin does not seem like a good idea in any case.....
  3. #3 Re: Cleaning Top end with Water rather than Seafoam
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Yes, it is touted as being just as effective. I prefer the Seafoam route, but it is not used to remove water.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  4. #4 Re: Cleaning Top end with Water rather than Seafoam
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    Dont internal steam clean unless you are 100% sure you know exactly what you are doing, yes it work, not its not good in the long run.
    Do the seafoam and forget it. seafoam actually eats away at the hardened carbon dceposits, the steam just takes off what it can get off and thats it, left with a rather turbulent intake track.
    Now, you can use up to 1/2 qt of auto tranny fluid, dexrons, with your motor oil to help clean the engine better and offer more protection to the seals then what motor oil offers. tranny fluid has alot more detergents and anti foaming agents then oil does.
    if you need to pass emmissions, try a bottle of isoprophyl alcohol, works wonders.
  5. #5 Re: Cleaning Top end with Water rather than Seafoam
    GTP Level Member dstout's Avatar
    ky
    I don't know if you have ever done seafoam or not but below is a link thats good.
    I take a soda bottle usually a clear one, make sure you have the screw cap and cut of the bottm of the bottle or even in half is fine also make sure the bottle is clean.
    I have some clear plastic tubing for the fishtank I think and the size you need is 7/16" x 5/16", about 12" will do.
    With a unibit or step bit I drill a hole in the bottle cap 3/8" and slide the tubing into the hole about 1/4" then attach the cap to the bottle and with electrical tape I tape the cap to the hose and the bottle just so the hose doesn't slip out.
    Dont drill the hole too big or it will leak the tubbing should fit tight in the hole.
    When you have done that disconnect a vacuum line and connect the hose to that vacuum line, it fits perfect and will not drip seafoam on the engine.
    It's a good idea to keep a rag or paper towel on hand in case it does drip.
    I wouldn't try the water cleaning. Check out the link.
    Dave
    Link here NYMCGP
  1. Tried Seafoam on my car with no smoke? did i do it right?
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2010, 11:51 PM
  2. intakes/exhaust/seafoam
    By FtBll Coach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-08-2009, 10:04 PM
  3. Throttle Body Seafoam????
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-25-2008, 12:42 PM
  4. Seafoam
    By J_Man55 in forum General Tech Discussion
    Last Post: 08-08-2008, 08:23 PM
  5. Seafoam Trans Tune any good?
    By 99BluGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-28-2008, 09:01 AM
