Thread: Are my pistons screwed?
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 84
  1. #1 Re: Are my pistons screwed?
    Quote Originally Posted by QwikGT View Post
    go with the L32 it comes with coated pistons and powdered rods stock low compression is more forgiving
    so powdered rods and coated pistons are stronger? logic is awesome.
  2. #2 Re: Are my pistons screwed?
    Fort Atkinson
    4 of 6 pistons chipped on my ex's "stronger" L32...box stock.
  3. #3 Re: Are my pistons screwed?
    HUDSON
    Open the top piston ring gap and that will not happen.
    Too much heat, not enough ring gap, equalls top ring land breaking off because the ring ends butt together and literally hold the piston in place a TDC while the crank tries to pull it down, and off come the ring land.
    Knock alone does not cause that. It is the sudden rise in cumbustion tempereature, and not enough heat transfer to the cyl. walls due to the thin, low drag rings used.
  4. #4 Re: Are my pistons screwed?
    Quote Originally Posted by QUICKSILVER462 View Post
    truth.
  5. #5 Re: Are my pistons screwed?
    PA
    And correct me if I am wrong, but the L32s are more prone to this.
    2001 GSE
  6. #6 Re: Are my pistons screwed?
    Donating Users blowfishRus6's Avatar
    g.a.
    intresting
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  7. #7 Re: Are my pistons screwed?
    HUDSON
    The l32 with the higher compression will be more likely to knock/pre-detonate. Remember, it is the heat that causes the ring end to close up to the point they touch and lock the piston in the bore, causing the ring land to break on the down stroke. Higher compression equalls more heat, which inturn will need a larger top ring end gap, espacially when boosted with a s/c, or turbo charger.
  8. #8 Re: Are my pistons screwed?
    the L32 has the same compression ratio as the L67. the L26 and L36 are the high compression n/a blocks.
  9. #9 Re: Are my pistons screwed?
    Fort Atkinson
    Did they run a tighter ring gap on the L32 motors? Or are the rings that much thinner then previous years? if filing and setting the ring end gap is all it takes,I won't have a problem running stock pistons. The car is staying stock I just don't want it to chip out more pistons.
  10. #10 Re: Are my pistons screwed?
    reno, nv
    Damn this is scary... What caused your car to start backfiring? Bad tank of gaS?
  11. #11 Re: Are my pistons screwed?
    Fort Atkinson
    mine or OP?
    This isn't from backfiring.
  12. #12 Re: Are my pistons screwed?
    reno, nv
    Quote Originally Posted by Thinkmoto View Post
    mine or OP?
    the OP.. He stated on his post that he thinks this happened when his car started backfiring and he took one of his spark plugs out and it was damaged.............
  13. #13 Re: Are my pistons screwed?
    g.a.
    if a spark plug is blow out and its not firing, yea that is gonna create a miss chiped pistion or not
    its slow.
  14. #14 Re: Are my pistons screwed?
    PA
    Quote Originally Posted by blowfishRus6 View Post
    Wait, how can your spark plug blow out?
    The issue is that excessive heat and knock combine to chip the top of the piston. Those chips coming off are what smash the spark plug and cause the miss. A spark plug doesn't get "blown out."
    2001 GSE
  15. #15 Re: Are my pistons screwed?
    g.a.
    ha well yea there you go. i was getting at a spark plug not firing is gonna cause a miss, chiped piston or not....
    its slow.
  16. #16 Re: Are my pistons screwed?
    reno, nv
    Yeah but i wonder what caused the car to start getting knock... Well im just wanting to know cause im interesting in buying one and i dont want to buy one that has a chipped piston As the OP stated that he didnt even know that the motor was hurt nor was the car acting up after that....... yet again, a smashed up spark plug is a real good indication of something real bad......
    05' turbo NEON 12.3 ET
    GTP soon to come......
  17. #17 Re: Are my pistons screwed?
    Fort Atkinson
    Quote Originally Posted by up in boost View Post
    The best explanation i've heard here is about the ring gaps being too tight from the factory. If that's the case then I'd be worried about every GTP out there. Personally if pistons chip out when running premium fuel then there is a problem with the design from the factory. Do these cars have knock sensors? I'm curious to what kind of protection is built into them/programmed in the ecu?
  18. #18 Re: Are my pistons screwed?
    yes, they have knock sensors. we avoid KR, which is the car pulling timing when knock is sensed. its our measurement to know when our car is running prime or not.
    you really dont have problems with chipping pistons if youre not knocking excessively and you dont do long WOT runs. highway runs are a good reason why people destroy these cars.
  19. #19 Re: Are my pistons screwed?
    Fort Atkinson
    So if your DD is a GTP and you drive it like grandma(my ex) and you still run into this problem? Not trying to be a dick but there has to be a reason outside of detonation.
  20. #20 Re: Are my pistons screwed?
    there are a lot of reasons you COULD blow up a motor. what did she do to it? run it short of oil or coolant? start the car up and immediately start driving even if its sub zero outside? there is a cause behind it, but what is it?
  1. UPDATE: Coolant in Engine/I screwed up
    By Panzer4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2009, 05:30 PM
  2. Im sooo screwed!
    Last Post: 11-27-2008, 01:00 PM
  3. Screwed?
    By Vegas~Blown in forum Brakes/Suspension/Chassis
    Last Post: 11-25-2008, 11:21 PM
