Thread: QUESTION: BRAKES; Top or bottom BOLT?
Results 1 to 5 of 5
  1. #1 QUESTION: BRAKES; Top or bottom BOLT?
    illinois
    Front brake caliper slide mount bolts. 1 is sort flat and 1 has plastic bushing tip. Which goes in top or bottom? And why?
  2. #2 Re: QUESTION: BRAKES; Top or bottom BOLT?
    I live here. UR LOSN's Avatar
    Rockford, IL
    Moved to correct area.
  3. #3 Re: QUESTION: BRAKES; Top or bottom BOLT?
    TDCRacing
    Guest
    Sorry kinda hard understang what you are asking.
    There should be plastic or rubber inserts in both. So the other one may be stuck in the caliper bracket.
  4. #4 Re: QUESTION: BRAKES; Top or bottom BOLT?
    SE Level Member 98SilvermistGTP's Avatar
    Nov 2008
    Eastern KY
    There is one caliper pin with a bushing and one without. The caliper pin with the bushing goes to the bottom on the front and the top on the back. They are made like this for just changing the pads. You can take the one without the bushing out and leave the other one with the bushing in and turn the caliper up or down to access the pads.
  5. #5 Re: QUESTION: BRAKES; Top or bottom BOLT?
    illinois
    98SilvermistGTP, my next door neighbor is a 30yr mech. And he says you are absolutely right.
  1. S/C bolt size question
    By TDCRacing in forum General Tech Discussion
    Last Post: 01-20-2009, 12:36 PM
  2. bottom end
    By rodman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2008, 11:01 AM
  3. Bolt Ons?
    By TMOTA503 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-03-2008, 10:06 PM
  4. Out The Top or Through The Bottom
    By SyntheticShield in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-20-2008, 01:07 PM
