Robotech
Between the time you changed your MAF and now, have you changed or cleaned your air filter? If you have a K&N Style filter those need to be oiled. Did you oil it? If so, how much oil did you put on it? Too much oil on the air filter is a bad thing. The excess oil comes off and begins to coat your MAF sensor which causes it to misbehave. So even if you only changed the MAF 7 months ago if you cleaned your air filter a couple times between now and then and over oiled it you could now have a very dirty MAF.
You can clean the MAF but you must be very gentle with it. A cotton swab with a bit of carb cleaner on it GENTLY rubbed VERY LIGHTLY over the wire will get most of the gunk off without harming it.
As for the fuel injectors, just getting some good FUEL SYSTEM cleaner will help. Don't get just the fuel injector cleaner...you want the stuff that cleans the WHOLE system. If that doesn't work it may be time for a little seafoam treatment. Nasty process but sometimes that deep kind of cleaning will help.
I'd check plugs first though as it's free and it may tell you a lot about how your car is running. That would help further diagnose the problem.
