Thread: the downpipe is KILLING me.
Results 1 to 18 of 18
  1. #1 the downpipe is KILLING me.
    SE Level Member pontiacgp759's Avatar
    Feb 2009
    Ada, OH
    alright fellas, i'm havin one hell of a time gettin this stock dp off. i've tried pb blaster, heatin it with a torch, using a hammer, everything until i stripped a bolt. i ended up drilling it out and only managed to remove that tonight. all of this took me 3 hours. By the way, these are the rusted mothers that are closest to the u-bend. worst comes to worst, ill strip out the other one trying to get it off and drill it out also. my only fear is the two bolts connecting the dp to the manifold. though they are hardly rusted, they are on there TIGHT and i'm afraid with the angle i might strip those out as well. Any advice would be great. whether its for the rusted one or the manifold bolts. I'm about to say screw it and take it to the shop down the road. Although i'd much rather save the money and try to get it done myself without damaging anything. I apologize for ranting but i feel like i wasted 3 hours of my life on one pathetic bolt. lol
  2. #2 Re: the downpipe is KILLING me.
    Jersey
    First of all, don't bother trying to un-bolt the bolts that connect the u-bend to the flange on the cat-back. I cut them with a saws-all. As far as the other 2 bolts on the manifold side, i soaked mine in wd-40 and let it sit for 20 minutes. Then hit it again with w-d. Then i made sure i had the right size socket and a breaker bar. I then set the socket and breaker-bar on the bolt, wedged miself out from under the car, and used my leg and foot on the breaker-bar, and got them loose. Work smarter, not harder
    16' wrx sti- stock
  3. #3 Re: the downpipe is KILLING me.
    Nov 2008
    Chicago
    I took one look at the ones by the ubend and decided i'd let the poor bastard im selling the old exhaust system to deal with it. The bolts by the manifold will take some time without an air ratchet and you will be sore in the morning. Use a few extensions on your ratchet to reach the bolt and use an extension bar if needed. I threw some blaster on mine about an hour before hand. they where tough, but not impossible. be very patient and you will get it done.
  4. #4 Re: the downpipe is KILLING me.
    GTP Level Member Scimmia's Avatar
    QCA, IA
    I was able to get the manifold to DP bolts without too much trouble with an extension and a breaker bar. The DP to catback bolts required heat and an impact, but came out in the end. Without air tools, you're probably gonna need a pipe with the breaker bar.
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: the downpipe is KILLING me.
    Nov 2008
    Chicago
    What's the trick for getting those pesky rubber exhaust hangers off?
  6. #6 Re: the downpipe is KILLING me.
    QCA, IA
    pry them off with a big screwdriver
  7. #7 Re: the downpipe is KILLING me.
    Nov 2008
    Chicago
    Quote Originally Posted by Scimmia View Post
    found out theres some plier like tool for this
  8. #8 Re: the downpipe is KILLING me.
    Quote Originally Posted by FuglyGTP View Post
    big screwdriver works just as good.
  9. #9 Re: the downpipe is KILLING me.
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    I figured I would be in the same boat if I tried to take my DP off myself as well. So I paid the local muffler shop $30 to swap it out for me in 15 min.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  10. #10 Re: the downpipe is KILLING me.
    Donating Users
    Plainfield, IL
    make sure to use 13mm socket on the mani to dp bolts and you'll be fine with an extension and a lil bit of muscle
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  11. #11 Re: the downpipe is KILLING me.
  12. #12 Re: the downpipe is KILLING me.
    Donating Users
    Plainfield, IL
    air tools.
    x2
  13. #13 Re: the downpipe is KILLING me.
    Donating Users blowfishRus6's Avatar
    g.a.
    god i wished i had some air tools sometimes.....
    all i can say is lots of wd-40 and give it time to soak it. i broke a few bolts myself doing the headers.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  14. #14 Re: the downpipe is KILLING me.
    Feb 2009
    Ada, OH
    hey guys thanks for the quick replies. luckily i have an air ratchet. i'm gettin them off today for sure. or at least i hope thanks again
  15. #15 Re: the downpipe is KILLING me.
    my brother is a mechanic and he swears by his air tools. he actually uses them for just the normal engine bolts and what not before he torques them down too.
  16. #16 Re: the downpipe is KILLING me.
    Jul 2008
    Fishkill, NY
    For the hangers, hit them with some silicone spray then put a jack underneath the down pipe to support it while you work it out of the hangers.
  17. #17 Re: the downpipe is KILLING me.
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    I used air tools and they came right off.
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  18. #18 Re: the downpipe is KILLING me.
    Feb 2008
    For mine, I sprayed all the bolts with PB Blaster, then ran the car for 10 minutes, then started working as soon as I could get my hands close to the exhaust. The heat and PB made them extremely easy to remove. Just don't burn yourself in the process. A nice thick pair of gloves may be necessary.
  1. my wife is on a killing spree!
    By stewartj1998 in forum Track Sessions and Kills
    Last Post: 04-15-2009, 10:39 PM
  2. Grand Prix killing spree
    By GreenPrix in forum Track Sessions and Kills
    Last Post: 03-09-2009, 02:22 PM
  3. senseless killing of a child
    By gtpinsc in forum The Rant Forum
    Last Post: 11-03-2008, 11:13 AM
  4. Which downpipe do I want?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2008, 09:38 AM
  5. killing KR
    By Smokedgtp in forum Turbo
    Last Post: 05-10-2008, 05:35 PM
