Thread: changing fluid and filter in tranny???
Results 1 to 15 of 15
  1. #1 changing fluid and filter in tranny???
    Donating Users blowfishRus6's Avatar
    g.a.
    questions. how much tranny oil does it need?? im guessing i just drop the oil pan in the tranny to do this?? is the gasket reusable?? is it hard to change the filter?? ive never done a tranny change. help is needed
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  2. #2 Re: changing fluid and filter in tranny???
    GTP Level Member Scimmia's Avatar
    QCA, IA
    7.4 qt for a pan drop/filter change, and yes, the filter is inside the pan.
    The gasket is reusable, and much better than the crap that will usually come with the filter.
    It's not hard to change, just try not to break the filter neck off (I've done it on Fords, but not on these, although I know someone that has), and don't mess with the seal unless you damage it.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: changing fluid and filter in tranny???
    g.a.
    good to know.
    and damn. i think royal purple was like 15$ a qt. f' that.
    its slow.
  4. #4 Re: changing fluid and filter in tranny???
    Aug 2008
    KCMO
    i was thinking about changing the fluid in my 04+ and while im in there i was thinking about putting a shift kit in. im bone stock but i just want my tranny to last longer any help on this would help so for the thread stealing
  5. #5 Re: changing fluid and filter in tranny???
    SE Level Member Crave Energy's Avatar
    Oct 2008
    San Jose
    The gaskets are reusable. If it looks nice and dry around the pan reuse it. Some times the rubber will start to crack especially close to the bolt holes, if that's the case, I'd recommend replacing it. The best one is the factory replacement from the dealer which should last as long as you have the car.
  6. #6 Re: changing fluid and filter in tranny???
    Barksdale AFB, LA
    Quote Originally Posted by blowfishRus6 View Post
    good to know.
    Dexron VI. End fluid decision.
    Quote Originally Posted by carl06GT View Post
    Shift kits aren't hard. Just get a quality kit (like the Intense kit) and not the crappy little spacers ZZP sells. Here's a thread from when I installed my Intense kit:
    http://www.naioa.com/v2/modules.php?...wtopic&t=27003
    2009 Subaru Impreza WRX STI
  7. #7 Re: changing fluid and filter in tranny???
    Nov 2008
    Chicago
    loosen bolts in proper order then take them off the rest of the way starting at one corner and working your way torwards the opposite corner. this way pan starts to tilt at an angle pouring the fluid into the pan and not all over you
  8. #8 Re: changing fluid and filter in tranny???
    Charles City, IA
    I would not drop the pan. Have someone flush your tranny with a tranny flush machine. When you just drop the pan you still have a ton of old fluid in there to mix with your new fluid.
    SMGPFC Two Nipple General
  9. #9 Re: changing fluid and filter in tranny???
    QCA, IA
    And if you don't drop the pan, you still have the crappy old filter. Take your pick.
  10. #10 Re: changing fluid and filter in tranny???
    Moore, Oklahoma
    Its better to replace your filter IMO. Its like changing your oil and not changing the filter.
    Shawn W. Larsen
  11. #11 Re: changing fluid and filter in tranny???
    huntington, wv
    Not wanting to res an old thread but I read about breaking off the neck on filter. I just did that. How do I get it out of the tranny?
  12. #12 Re: changing fluid and filter in tranny???
    hook and rip it out.
  13. #13 Re: changing fluid and filter in tranny???
    Denver
    Vise grips is what I use. If you use the bigger ones you can cam the insert out rather than try and do a straught pull.
  14. #14 Re: changing fluid and filter in tranny???
    Feb 2010
    TN
    I usually drop the pan and change the fluid I know this leaves old fluid in the tranny but I change it once a year which is roughly 20-25,000 miles
  15. #15 Re: changing fluid and filter in tranny???
    If you are fighting and harbor freight is nearby, get a blind pilot bearing tool. It works fantastic for this and coolant elbow remnants.
  1. Changing that oil filter. I need tips
    By Z28 in forum General Tech Discussion
    Last Post: 01-10-2011, 01:13 PM
  2. Help!! Tranny leaking fluid
    By NMillis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-12-2009, 06:48 AM
  3. What Tranny Fluid should I run?
    By Iron Indian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-15-2009, 01:24 PM
  4. tranny fluid change ?
    By NEONNIGHT34609 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-19-2008, 09:48 AM
  5. Changing Flexplate - don't have to drop the tranny ?
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2008, 12:56 PM
