Thread: Power comes & goes to trip computer/HVAC
Results 1 to 20 of 38
  1. #1 Re: Power comes & goes to trip computer/HVAC
    Apr 2011
    up state ny
    Quote Originally Posted by FoSHO99 View Post
    It bypasses a relay in the ignition that tends to die out slowly and is hard to get to, hence why they thought of making a bypass relay that is easier to replace. Flashing Dic/dic off sometimes and coming back on, other electrical issues in the car such as heated seats stop working, possibly blower motor resistor, that stuff is possibly related.
    I have replaced the ignition switch and still no power to both the DIC and HVAC control panel. Where is this factory relay located? I'll replace it, but this bypass looks to complicated.
  2. #2 Re: Power comes & goes to trip computer/HVAC
    SE Level Member jmt455's Avatar
    SE Michigan
    The original circuit is fed directly from the ignition switch to the fuse DIC/HVAC fuse. It is located in the fuse panel to the right of the glove box.
    Did you follow the diagnostic check to see if there was 12V at the fuse block? If you have constant 12V there, the problem is not caused by the ignition switch.
    If you have 12V at the fuse block and the fuse is not blown, you'll be looking for an open 12V feed from the fuse block.
    83 Bonneville wagon
    08 G8 Base
  3. #3 Re: Power comes & goes to trip computer/HVAC
    May 2013
    New York
    Quote Originally Posted by jmt455 View Post
    Can anyone tell me the location of the relay though? i realize this is an old thread...
  4. #4 Re: Power comes & goes to trip computer/HVAC
    Apr 2011
    up state ny
    To all with this same problem....save your money, it wasn't the ignition switch harness.
    The fix to this was nothing short of a bad wire found in the wire bundle plug connection at the firewall under the hood.
  5. #5 Re: Power comes & goes to trip computer/HVAC
    May 2013
    detroit
    Quote Originally Posted by Afterburn View Post
    can you provide any information on the bad wire you found? location/better description? thank you.
  1. First Long Trip. Need some help fixing some annoying problems!!
    By gpIA in forum General Tech Discussion
    Last Post: 02-24-2009, 10:24 PM
  2. Making the trip to sthe strip!
    By GTP4 in forum Track Sessions and Kills
    Last Post: 10-16-2008, 08:06 PM
  3. What tune up's to do before long trip?
    By 98gpgt98 in forum Off Topic Discussion
    Last Post: 06-22-2008, 09:13 PM
  4. Last minute weekend trip?
    By BabyBlue in forum Midwest
    Last Post: 05-09-2008, 03:56 PM
  5. Just got back from my trip (Pictures)
    Last Post: 04-23-2008, 05:17 PM
