Quote Originally Posted by dmoney01 View Post
ya i greased the pins on both sides and it helped a little bit but didnt fix the problem, my rotors feel like they have grooves in them when you slide your finger across them, do you think that could be the problem? oh and i jsut replaced the breaks to
You relaced the brake pads? If so you're more than likley going to need new rotors and pad's
It sounds like you're pads got worn down to much before replacing them and were causing metal to metal contact with the rotor's. You then changed the pads with new ones.
The vibration is because of the grooves in you're rotor's. You may be able to get by with just rotor's depending on how the pads look.
