Thread: P0410 Secondary Air Injection System Malfunction
Results 1 to 20 of 21
  1. #1 P0410 Secondary Air Injection System Malfunction
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    This is the code I'm pulling (p0410).. was wondering if you guys thought if I should just replace the pump.. or if it's worth trying to fix somehow? from what i've been reading it seems like the thing freezes up in the winter sometimes.. but it's definitely warm enough that it shouldn't be frozen still.. maybe corrosion? should I just replace the pump or what? no part stores around here carry the part so I'd have to order it online.
  2. #2 Re: P0410 Secondary Air Injection System Malfunction
    Medford, NY
    hmm well i bought a smog pump.. but cant find the freakin thing in my engine!.. if it was there.. where would it be located? (01 gt) is it possible I don't have one and something else is throwing out this code? what could it be?
  3. #3 Re: P0410 Secondary Air Injection System Malfunction
    GTP Level Member Scimmia's Avatar
    QCA, IA
    I believe it's located down below the airbox, assuming you have one at all. AFAIK, it was part of the California Emissions package (it was on the Regals, I assume the GPs are the same), so most of our cars don't even have one at all. Don't think you would throw the code if your car didn't come with one, though.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: P0410 Secondary Air Injection System Malfunction
    Medford, NY
    yeah i think i found it.. couldnt see it because the coolant reservoir.. if i have time i'll take pics and do a write up on it for everyone else.. i'll probably be in too much of a rush though
  5. #5 Re: P0410 Secondary Air Injection System Malfunction
    Medford, NY
    nope its definitely not by the coolant tank lol... man i hope its under the airbox.. that's the only place i havent looked.. it better not be under the engine by the cat..
  6. #6 Re: P0410 Secondary Air Injection System Malfunction
    SE Level Member srziemkowski's Avatar
    Jul 2008
    ENGLEWOOD florida
    here is the description of that code,there is 43 steps on the flow chart to repair this and could be a pain,it says to first check the air pipes and hoses,then vaccum hoses,there is a couple parts it talks about relacing before the pump.The control module activates the secondary air injection (AIR) system by grounding both the pump relay and the vacuum control solenoid control circuits simultaneously. This action energizes the AIR pump and the vacuum control solenoid. Vacuum is then applied, opening the valves. The pump then forces fresh air into the exhaust stream in order to accelerate catalyst operation. The control module will run up to 3 diagnostic tests using the pre-catalyst heated oxygen sensor (HO2S) voltage and Short Term FT to diagnose the system. The system can be diagnosed during normal secondary air injection operation or the control module can activate the system specifically for diagnostic purposes. If an air flow condition is detected, this diagnostic trouble code (DTC) will set. When inactive, the system prevents air flow in either direction. hope this helps
    Big Black
  7. #7 Re: P0410 Secondary Air Injection System Malfunction
    Jul 2008
    ENGLEWOOD florida
    sometimes its nice to be a service writer at a chevy dealer,lol
    Big Black
  8. #8 Re: P0410 Secondary Air Injection System Malfunction
    Medford, NY
    haha thanks that was very informative.. it was the pump.. when i pulled it off. water poured out.. and i tried to move the fan.. it was stuck.. so it corroded from being inactive.. weird thing though.. when i pulled the gasket off it pulled a peice of plastic from the housing off with it.. broke in 3 peices.. i tried to seal it... but we'll see if that holds up.. and that bracket was such a pita to get to.. so i made my own hanger and just took the bracket out (since i'll probably have to replace the pump again anyway)
    it was underneith the air filter housing.. but you couldnt see it just by taking the housing off.. and there was no way to get to it unless you go under the car.. man i hated that job.. im wiped out now lol it's just nice to see the ses light off and hear that motor turn on when i turn on the car!
  9. #9 Re: P0410 Secondary Air Injection System Malfunction
    Jul 2008
    ENGLEWOOD florida
    cool,glad its out for ya
    Big Black
  10. #10 Re: P0410 Secondary Air Injection System Malfunction
    Medford, NY
    thanks.. the next head ache is how to take the stock fuel filter off an 01 gp without breaking the fuel line...
  11. #11 Re: P0410 Secondary Air Injection System Malfunction
    Jul 2008
    ENGLEWOOD florida
    good luck
    Big Black
  12. #12 Re: P0410 Secondary Air Injection System Malfunction
    Nov 2008
    Chicago
    secondary air injection... if that only meant we had two superchargers...
  13. #13 Re: P0410 Secondary Air Injection System Malfunction
    Medford, NY
    it kind of sounds like one lol
  14. #14 Re: P0410 Secondary Air Injection System Malfunction
    Medford, NY
    okay i'm going to update this a little bit because I'm STILL messing around with this thing... i replaced the pump (yes it was corroded and now it doesn't blow the fuse).. i can hear the pump turn on.. sounds like its fixed.. but in the middle of driving the SES light comes back on.. same code (p0410) so today i took the hoses off.. cleaned them out.. made sure the connections were good.. i also took what i believe to be the electric air valve off (kind of looks like an egr).. i cleaned it out.. put it all back together.. what do ya know, the code comes back up!!!.. also i took the pump apart.. there was a good amount of water inside the pump that I dumped out.. i dont know if I should replace the valve or what I should do.. maybe replace the vacuum control solenoid?
    any help or suggestions would be awesome.. this is bothering me so bad because it's the ONLY thing wrong with my car and probably the only thing I have no idea about.
  15. #15 Re: P0410 Secondary Air Injection System Malfunction
    Medford, NY
    update.. replaced the solenoid.. didn't fix it.
  16. #16 Re: P0410 Secondary Air Injection System Malfunction
    Liverpool, ny
    Did you change the fuse for the pump? Mine was throwing fuses left and right and causing my SES light to come on. Its in the underhood fuse box.
  17. #17 Re: P0410 Secondary Air Injection System Malfunction
    SE Level Member crazyGPlover's Avatar
    Springfield, MA
    my car has this same problem, i am also going through all this crap. i dont want to take it to anywhere to get it fixed when i could just fix it at home where i have my own garage and lift. but i think i might just take it to the diagnostic center to pinpoint the exact problem, because im tired of replacing things and it not getting fixed...
  18. #18 Re: P0410 Secondary Air Injection System Malfunction
    QCA, IA
    The fix is simple, use a tuner to disable the codes and removed the damned thing.
  19. #19 Re: P0410 Secondary Air Injection System Malfunction
    Springfield, MA
    thats not going to help when inspection time comes because the code will not be there and it will say not ready and then it fails for emissions anyways. happened to a friend of mine that way with his car with another issue.
  20. #20 Re: P0410 Secondary Air Injection System Malfunction
    chicopee Ma.
    just change the fuse i beleive its a 30 amp i have the same probbly in the winter with my blazer or you can change the check valve . i just do the fuse in the spring when it get warmer out once a year the pump is pricy
  1. Washer Fluid Injection
    By 98GT3800 in forum General Tech Discussion
    Last Post: 10-21-2008, 11:51 AM
  2. Ethanol injection
    By IndeedSS in forum Off Topic Discussion
    Last Post: 09-03-2008, 09:45 AM
