Thread: DIC Shows Incorrect Day of the Week
Results 1 to 7 of 7
  1. #1 DIC Shows Incorrect Day of the Week
    SE Level Member wrngway's Avatar
    I have a 2004 GTP. I just noticed that the day of the week in the DIC is off. I checked the date and entered 22 Jan 2008 for today, and the DIC says it's Wednesday.
    At first I thought I had the wrong year, but that's not it. Has anyone else seen this before?
  2. #2 Re: DIC Shows Incorrect Day of the Week
    GTP Level Member TyroElite's Avatar
    Williamsport, PA
    Hmmm... i just read something about this in the service manual maybe? I'll see if I can find it again.
  3. #3 Re: DIC Shows Incorrect Day of the Week
    Williamsport, PA
    Ok, here it is:
    Day of the Week and Date Do Not Agree on Drivers Information Center (DIC) on Vehicles Equipped with 6-Disc CD/Radio (Replace Radio) #04-08-49-001B - (May 26, 2004)
    Day of the Week and Date Do Not Agree on Driver's Information Center (DIC) on Vehicles Equipped with 6-Disc CD/Radio (Replace Radio)
    2004 Pontiac Grand Prix
    with RPO PCJ -- Premium Sound System
    This bulletin is being revised to update the repair procedure and Warranty Information. Please discard previous Corporate Bulletin Number 04-08-49-001A (Section 08-Body and Accessories).
    Condition
    Some customers may comment that the day of the week and the date do not agree as shown on the Driver's Information Center (DIC).
    Cause
    This condition is caused by an anomaly in the 6-disc CD/radio software for vehicles built prior to January 6, 2004.
    Correction:
    Important
    Determine if the vehicle was built prior to January 6, 2004, by running the VIN in GMVIS. Vehicles built January 6th and later already contain the new radio software.
    Permanent Solution:
    A supply of 6-Disc CD/radios with updated software are now available through the 8 US Electronic Service Centers (ESC's) / 3 Canada SuperStores. A list of Exchange Centers/Superstores can be found at the end of this bulletin.
    Important
    • Due to limited supplies of the 6-disc CD/radio, it is imperative that radios are not ordered for stock.
    • Unless you request the correct part number, the radio and HVAC heads will NOT match.
    There are currently three different part numbers for the 6 disc CD/radios that are in vehicles which have been built prior to January 6, 2004. To insure the correct replacement radio is shipped, the correct part number of the radio from the vehicle you are servicing must be supplied to the exchange center. The radio part number must be obtained by following the steps using the Tech 2®:
    1. Enter the "diagnostics" section of the Tech 2® for the 2004 Pontiac W-Car
    2. Select F1: Body
    3. Select F7: Radio
    4. Select F1: Data Display
    5. Select F0: Module Information to obtain the 8-digit radio part number
    Important
    The replacement radio will come packaged with a pre-printed overnight shipping label. To help replenish the stock at the reman centers, it is critical that the original radio be repackaged and shipped to the reman centers upon receipt of the replacement radio immediately after removal of the radio from the customer's car. This will minimize 6-disc CD/radio shortages at the reman/exchange centers.
    For vehicles repaired under warranty, use:
    Labor Operation
    Description
    Labor Time
    R0760
    Receiver, Radio -- Remove, Repair and Replace
    0.4 hr
    Add:
    To Set-up Radio
    0.1 hr
    Add:
    Diagnosis Time
    0-0.3 hr
    US ELECTRONIC SERVICE CENTERS
    AER Technologies (AEL)
    1841 W. Commonwealth Ave
    Fullerton, CA 92833
    714-871-7357
    1-800-321-6970
    Fax: 714-446-6105
    AJR International, Inc. (AJC)
    951 North Larch Ave
    Elmhurst, IL 60126
    630-832-0222
    1-800-232-3965
    Fax: 630-832-0333
    Autocraft Electronics (AED)
    1612 Hutton Dr
    Suite 120
    Carrollton, TX 75006
    972-466-6200
    1-800-336-3998
    Fax: 972-466-6340
    Instrument Sales & Service, Inc (ISS)
    18814 72nd Ave S
    Kent, WA 98032
    425-251-5469
    1-800-666-5469
    Fax: 1-800-272-3628
    Model Electronics Inc (MES)
    318 Roosevelt Ave
    Spring Valley, NY 10977
    845-356-5669
    1-800-433-9657
    Fax: 845-356-1189
    Specmo Enterprises (SED)
    32655 Industrial Dr.
    Madison Heights, MI 48071
    248-307-2570
    1-800-545-7911
    Fax: 248-307-2571
    Fax: 1-800-682-3799
    Speed-O-Tach, Inc (SPS)
    4090 Pike Lane
    Concord, CA 94520
    925-691-4090
    1-800-442-4491
    Fax: 925-691-4101
    Techni-Car, Inc (TCT)
    450 Commerce Blvd
    Oldsmar, FL 34677
    813-855-0022
    1-800-886-0022
    Fax: 813-855-2101
    CANADA SUPERSTORES
    York Electronics Ltd
    #5, 1430-28th Street N.E.
    Calgary, Alberta T2A 7W6
    403-291-5141
    1-800-361-2894
    Fax: 403-291-5483
    Fax: 1-800 361-5396
    Masscomp Electronics
    40 East Pearce Street
    Richmond Hill, Ontario L4B 1B7
    905-764-9533
    1-800-463-0762
    Fax: 905-764-7476
    Technicentre Plus
    6825 Place Pascal Gagnon
    Montreal-Nord, Quebec H1P 2V8
    514-327-1122
    1-800-361-4124
    Fax: 514-327-3694
  4. #4 Re: DIC Shows Incorrect Day of the Week
    Thanks!
    I'm out of warranty, so maybe I'll just change the year to show the right day.
  5. #5 Re: DIC Shows Incorrect Day of the Week
    Williamsport, PA
    That'd work too!
  6. #6 Re: DIC Shows Incorrect Day of the Week
    You know, it's funny because it was working just fine last year. Maybe it has something to do with it being a leap year? Who knows....
  7. #7 Re: DIC Shows Incorrect Day of the Week
    SE Level Member scooz14's Avatar
    West Bloomfield MI
    my gf had that issue in her 05, but halfway through the day, the day would be right.
    turned out she had am and pm switched.
    12.591@108.00 1.95 60'
    329.9hp 400.1tq
    http://www.mccgp.com/member_details.php?mid=95
  1. Week #1 of GrandPrixForums.net
    Last Post: 04-17-2014, 11:38 AM
  2. what TV shows?
    By UR LOSN in forum Off Topic Discussion
    Last Post: 03-23-2008, 10:10 AM
  3. Incentive Car of the week Cal
    By J_Ferguson in forum Forum Bugs/Suggestions
    Last Post: 01-16-2008, 11:13 PM
