Moved to correct section.
There could be a couple of issues here. One could be your blow motor is actually going bad and causing the blow resistor to overload. The other like you mentioned could be the problem as well. Contact Reptile here on the boards, he and Abrasive are selling an item that helps to illiminate the problem of water getting into the blower motor.
I hope that helps!
And welcome to the forums too!
