Thread: the good and the bad....PCM's ????
Results 1 to 9 of 9
  1. #1 the good and the bad....PCM's ????
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    what is good? I have heard good things about Intense, and bad things about ZZP. but what about this one i found from 3800 Performance? from what it lists, it sounds good to me (for what I need)
    here it is...
    PCM for Grand Prix GTP v1.0: 3800 Performance
  2. #2 Re: the good and the bad....PCM's ????
    I live here. UR LOSN's Avatar
    Rockford, IL
    moved to correct section......
  3. #3 Re: the good and the bad....PCM's ????
    Aug 2008
    Long Island, New York
    i had a zzp pcm in my last gtp, i got lucky and it gave me no problems, and performance wise it wasnt bad. i think 3800 performance gets theirs from zzp actually (correct me if im wrong). Intense i heard is good, it is the one i am probably gonna get, i would get that or one from overkill if i were you. But really nothing is better than tuning it yourself
  4. #4 Re: the good and the bad....PCM's ????
    Charles City, IA
    I would not get one from zzp. I would go to overkill or TDC on this site. I have a zzp one and the tune is junk. With all the mods in my sig I am still getting up to 6* KR. I should be able to run a smaller pulley with none, if I had a good tune.
    SMGPFC Two Nipple General
  5. #5 Re: the good and the bad....PCM's ????
    Dec 2008
    Canada
    Well you can order a PCM from Will at Overkill he is based out of Toronto. Here is the link even though it's 169$ I will either go with Overkill/Intense or a buddy is just learning to tune so I might get him to do it
    :: Overkill Motorsports ::
  6. #6 Re: the good and the bad....PCM's ????
    GT Level Member nutcase's Avatar
    Washington State
    I have a 3800 PCM. I can definitely tell the diff between the stock and this one. not sure if its the greatest since i have yet to try a different brand.
    My car doesn't leak oil,
    It marks it's territory.
  7. #7 Re: the good and the bad....PCM's ????
    the one from 3800 performance (DHP 1.0) is a pretty decent base tune, but beyond a 3.4 pulley setup you really should have a tune done specifically for your car.
  8. #8 Re: the good and the bad....PCM's ????
    Oct 2008
    mascoutah, Il
    i definitely agree, mail order tune will only do so much.
    2002 GTP
    custom HOK paint
  9. #9 Re: the good and the bad....PCM's ????
    Washington State
    ohhh! did not know that! I have a stage 5 and it was all just put in...nothing tuned.
    I..I have more power potentially???
  1. What problems come with switching PCM's?
    By gdbyrd in forum PCM Tuning
    Last Post: 03-19-2009, 11:13 AM
  2. Overkill PCM's
    By spidamanSS in forum PCM Tuning
    Last Post: 10-16-2008, 08:13 PM
  3. Reprogramed PCM's
    By Dohner in forum General Tech Discussion
    Last Post: 07-13-2008, 11:21 AM
