Thread: ughhh, trunk wont open!
Results 1 to 5 of 5
  1. #1 ughhh, trunk wont open!
    GT Level Member black98gt's Avatar
    Rochester NY
    Ok, so the button on my key fob doesnt work, I dont know why. And now the key wont even open the trunk! Its like its not going in all the way.
    When I press the button on the fob, I can hear a clicking noise coming from the BCM. Could it be the relay or do I need to buy a new trunk release selenoid? Im gonna buy a new trunk lock tomorrow. And ofcourse, my right blinker went out in my tail light!
  2. #2 Re: ughhh, trunk wont open!
    SE Level Member Boosted02GTP's Avatar
    Feb 2009
    Long Grove IL.
    The relay would be easy to test...just jump a wire to it and listen..if it pops it works.
  3. #3 Re: ughhh, trunk wont open!
    SE Level Member TheGreatSamG's Avatar
    Oct 2008
    chicago
    same thing happened to my car. but the button works. just not the key. im not worried. but when you do get it open. get someone to press the botton while u look at it. thats how i fixed my button problem.
    mine had a bunch of garbage and nasty gook all over it
  4. #4 Re: ughhh, trunk wont open!
    Donating Users
    Plainfield, IL
    if you have a loud system you can mess your lock up i had a car with a loud system and it ruined the trunk lock....grew out of having rediculously loud music im only 20 so more like a had a kid and it forced me to grow out of it lol anyway have you checked your reverse lights fuse under the hood the trunk pop is wired in with this fuse so if you have no reverse lights then that could be it....then at least the fob and button in the car will work if its just that fuse....your lock it prob messed up internally though
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  5. #5 Re: ughhh, trunk wont open!
    Rochester NY
    reverse lights dont work, ill check...
  1. Passenger side door wont open
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 01-05-2009, 01:08 PM
  2. How do I fix my door swinging open?
    By onehitznj in forum General Tech Discussion
    Last Post: 12-07-2008, 10:37 PM
  3. Finish Line Performance (FLP) Open House June 21st
    By beastin1 in forum Shows and Events
    Last Post: 06-18-2008, 05:26 PM
  4. stuck in open loop and LTFTs pegged at 0.0%
    By fst in forum PCM Tuning
    Last Post: 05-02-2008, 08:57 AM
  5. open air filter in engine bay
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2008, 04:21 PM
