Thread: Light Question?
Results 1 to 10 of 10
2001camaroB4C Light Question? 01-02-2009, 09:42 PM
Guest Re: Light Question? 01-03-2009, 09:58 AM
Warhellride Re: Light Question? 01-03-2009, 03:24 PM
Warhellride Re: Light Question? 01-03-2009, 03:49 PM
2001camaroB4C Re: Light Question? 01-04-2009, 08:39 PM
Warhellride Re: Light Question? 01-11-2009, 03:24 PM
Warhellride Re: Light Question? 01-11-2009, 03:25 PM
bronzegp Re: Light Question? 03-09-2009, 12:23 PM
Toofastgs Re: Light Question? 03-09-2009, 12:30 PM
bronzegp Re: Light Question? 03-09-2009, 12:50 PM
  1. #1 Light Question?
    SE Level Member 2001camaroB4C's Avatar
    My headlights are basically useless. I was thinking of swapping to silverstars like I have in my other car but I thought I would ask. What, aside from hid's, is the brightest high and low beam bulb I can put in my stock housing.
    And I have read about people swapping to 55 watt fog lights. What is involved with this? A relay and a glass housing?
    Also I was able to do a few minor things to my Camaro so that all six bulbs are on when I have my brights on. Is this possible in a Grand Prix?
    I want the most possible light coming out of the front of my car without the cost of HID's.
    Thanks
    2001 A4 Camaro B4C, 1.94 60ft - 8.48 1/8@84.13 - 13.17@104.29, should go faster with a better track and no ses light.
    And now a 98 Grand Prix
  2. #2 Re: Light Question?
    TDCRacing
    Guest
    Well silverstars did not make any difference in my mustang. But that is probably about the best you can get without hid's
  3. #3 Re: Light Question?
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    Headlights:
    For brighter headlights with the stock capsules, the best thing you can do is get a relay harness (link). The harness will have a greater effect on your light output than any bulb will. For bulbs, I'd recommend the Philips X-treme Power +80 (link).
    Foglights:
    You'll need to swap to a glass housing to use 55W foglight bulbs (almost all aftermarket foglights for our cars use H3 bulbs). To mount them, you'll have to drill a couple of holes into the stock brackets. It's not that difficult, and they can be easily returned to stock if you want to.
    For what you're looking for, you'll probably want a driving light (more like a spotlight or high beam) instead of a foglight (low, wide beam). One easy way to tell is that foglights usually have a reflector over the bulb, while driving lights normally do not. I've heard good things about the Cyberwhites (blue tinted lens), which are available at most auto parts stores or WalMart, and the Hella Angel Eyes (link).
    Running all the lamps at once:
    Our headlights use a dual filament bulb. You can't have both the high and low beam filaments on at the same time without burning out the bulb. It's possible to wire the foglights to stay on with the highbeams, but I don't remember how.
    Last edited by Warhellride; 01-11-2009 at 03:27 PM. Reason: Make links more visible
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  4. #4 Re: Light Question?
    One more question: How clouded are your headlight capsules? The most noticeable difference I've seen was when I replaced my scratched and clouded capsules with new ones.
  5. #5 Re: Light Question?
    Quote Originally Posted by Warhellride View Post
    One is crystal clear and the other is a little clouded. I think the bulbs are really old just replacing them would probably help a lot. When you said a relay harness what is that? is there a writeup somewhere?
    I forgot about the dual filament thing I found the thing about keeping the fogs on with the highs and I might do that.
    Thanks
  6. #6 Re: Light Question?
    A relay harness connects your headlights directly to the battery. This results in more voltage to the bulbs. There are writeups to make them yourself, or you can purchase them premade. If you buy one premade, it's pretty easy to install.
    There are a lot of harnesses out there. I've heard good things about these, and the price seems pretty good:
    3B Specialties : Home
  7. #7 Re: Light Question?
    I also found the writeup for keeping your foglights on with your high beams:
    http://www.grandprixforums.net/f73/f...eams-7318.html
  8. #8 Re: Light Question?
    Dec 2008
    Michigan
    Is is possible to get a brighter bulb without changing anything at all and be worry free of anything melting?
    I am going to get new headlight assemblies for my 2000 gt, but I want to get newer and brighter bulbs. Any ideas for the question above? And any links to a cheap but new set of headlight assemblies (no cornering assembly needed).
    Thanks
  9. #9 Re: Light Question?
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    If you want the most light output with out spending the buxs for hids.
    Silver stars are not the best. They are a tinted bulb which is bad.
    Narva RangePower+50, GE Night Hawk, Philips VisionPlus, and Tungsram Megalight Premium. These are the ones you should look at, as these will provide the most light output
    The silverstars we sell in America are not the "REAL" ones in fact they are a knock off. The real ones come in a blue and white packaging if i remember right and are only made in germany and will not have any color coating on the bulb
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  10. #10 Re: Light Question?
    Dec 2008
    Michigan
    what's the highest wattage bulb I can put into a stock fog and headlight set-up?
  1. SES Light
    By sws922 in forum General Tech Discussion
    Last Post: 11-01-2008, 01:30 PM
  2. ZZP dp & SES light
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 01:47 PM
  3. Gas Cap Light
    By uti grand prix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-24-2008, 01:20 PM
  4. help... my ses light is on
    By kingd44 in forum General Tech Discussion
    Last Post: 03-07-2008, 09:45 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
