Thread: Ignition not turning
Results 1 to 7 of 7
  1. #1 Re: Ignition not turning
    Jan 1970
    Maquoketa, Iowa
    Make sure the car is in Park if not already.
    If you have small hands, there is a release button just below where you put the key in. Once you push this button, it will let you take the key out. There was a diagram explaining this but I can't find it right now... its just a button you reach up underneath and have just enough room to press it with your fingers.
  2. #2 Re: Ignition not turning
    colorado springs
    the key is not stuck and the car is in park. i cant put it in and take it out. its just when i put my key in and try to start my car. doesnt turn at all.
  3. #3 Re: Ignition not turning
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by alee90 View Post
    It could be the switch that tells the car is in park is faulting out or broke, or your contacts in the ignition are dirty. Try moving the car from park to 1st a couple times and see if that helps???
  1. Trouble turning over
    By Halfy in forum General Tech Discussion
    Last Post: 08-23-2010, 11:49 AM
  2. Having problem my car keeps on turning off
    By krazyog1 in forum 04+ Specifics
    Last Post: 09-09-2009, 08:49 PM
  3. Turning a 01' SE into a GT
    By Dangerous313KidInAPrix in forum Visual/Body Modifications
    Last Post: 03-03-2009, 09:17 PM
  4. My 08 is turning out to be a LEMON
    By willie769 in forum The Rant Forum
    Last Post: 01-07-2009, 07:54 AM
  5. TCS not turning off
    By Keet04GTP in forum General Tech Discussion
    Last Post: 08-06-2008, 02:57 PM
