Thread: performance shift and TCS
Results 1 to 20 of 30
  1. #1 performance shift and TCS
    Donating Users
    Plainfield, IL
    two things:
    1) i heard that driving with TCS on results in powerloss? true? i just got my GTP so jw.
    2) and does driving with Perf Shift on result in poorer gas mileage?
  2. #2 Re: performance shift and TCS
    Donating Users
    W-S, NC
    The traction control is there for a reason. I wouldnt drive with it off but thats me, now if you gonna run someone or at the track then yes turn it off. The only way the traction control will cause you to lose power is if there is wheel spin.
    As for the performance shift, your foot will result in poor gas milage as the perf. shift changes the firmness of the shifts.
  3. #3 Re: performance shift and TCS
    Donating Users chrisb's Avatar
    Bucyrus, OH
    ^^i think he covered it nicely!
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  4. #4 Re: performance shift and TCS
    Moore,OK
    and raises shift points slightly. it also stays in gear longer at part throttle and downshifts faster. i leave mine in perf shift all the time. i've got a fairly heavy foot and still get 21mpg combined.
    Last edited by whiteknuckle; 10-09-2008 at 10:29 PM. Reason: add: at part throttle
    99 gtp
    14.7@92mph 2.1 60ft .290 r/t STOCK
    :SOLD: Mistake
    2005 GXP???
  5. #5 Re: performance shift and TCS
    SE Level Member 02gp40th's Avatar
    Oct 2008
    Lloydminster
    Dumb Question, How For sure do you know you have the perfect shift option, i don't see the switch people talk about. my car is the 2002 grand prix GTP 40th anniversary. I see there should be a light in the instrument panel that lights up, mine doesn't light up? any answers would be appreciated. Sorry for jacking the thread! just a side step lol
  6. #6 Re: performance shift and TCS
    Quote Originally Posted by 02gp40th View Post
    I believe the Preformance Shift button was not on cars after 2000 but the light was still in the dash for some reason.
  7. #7 Re: performance shift and TCS
    ^the button is on the side of the shifter! u can't miss it.
    and when u here it click in. (on) there should be a blue light in your instrument panel. (left side) it sounds like your bulb is burnt out tho! you'll know when u have it on. the tranny will shift harder!
  8. #8 Re: performance shift and TCS
    Donating Users
    W-S, NC
    Quote Originally Posted by boosting98 View Post
    Yep, I get to have the fun of replaceing mine... mine went out last week.
  9. #9 Re: performance shift and TCS
    Oct 2008
    Lloydminster
    I swear there is no button on the shifter lol, its on 02 gtp 40th anniversary are you shure it's an option? i looked all over i'll take pictures haha!
  10. #10 Re: performance shift and TCS
    Oct 2008
    Lloydminster
    ooohhh....that SUCKS! lol i was all excited
  11. #11 Re: performance shift and TCS
    Oct 2008
    Lloydminster
    OOOHH i looked on ebay for one, and i found one with the button, mine is defintly different
  12. #12 Re: performance shift and TCS
    Moore,OK
    i THINK there is a write up in here somewhere on how to turn the perf.shift on on cars without the button.
    99 gtp
    :SOLD: Mistake
    2005 GXP???
  13. #13 Re: performance shift and TCS
    Oct 2008
    Lloydminster
    Oh really, does anyone know about this?
  14. #14 Re: performance shift and TCS
    Donating Users
    W-S, NC
    I know with some aftermarket pcms, they program the pcm to run performance shift all the time. ZZPhas this to say about their pcm's( altho I wouldnt recomend them but others have the same setup). On 97-00 GTP's, performance shift mode must be selected to enable shift points and line pressure modifications. On all other PCMs, we program in the performance tables to run all the time unless otherwise requested.
  15. #15 Re: performance shift and TCS
    St. Louis Mo.
    Here is my Tech Tip How To on installing the Performance Switch on GP's that do not have it installed.
    http://www.grandprixforums.net/f73/a...shift-701.html
    I hope this helps ya! Also IF you have the GTP DIC, the one that has the Boost Gauge meter graphic on it, you will have the Performance Shift option inside of it. NOT all DICs have this. Only the ones with the Boost Gauge meter on it generally have it. I can not say for the rest.
    There are many options on how you may want your PS to work. ie Toggle Switch, Full time mode (grounded on permanently), or finding a used Shifter with the PS button in it. My write up helps you to get the PS working in your car, the way you engage it is upto you.
    James Shafer
    St. Louis MO
  16. #16 Re: performance shift and TCS
    Oct 2008
    Lloydminster
    Ahhhh I see!
  17. #17 Re: performance shift and TCS
    Donating Users bgn87's Avatar
    Kinnelon, NJ
    Performance shift was not on the 2001+ GTP I believe. The only way to get it is to have an aftermaket PCM like DHP or ZZP. You don't necessarily need a shift knob with the switch.
    Here's a writeup of how to do it
    RivMan's Page
    Instead of performance shift knob, I have mine just grounded to the chassis so it's on all the time.
    2002 GTP - 13.66 @ 102.77
    Rolling Performance
  18. #18 Re: performance shift and TCS
    I have an '03. I do believe the 2001's had the Performance Shift option, but the light was on the dash in blue, not the DIC.
    I can still control mine, but I leave it on ALL the time b/c you never know when you are gonna be needing it
  19. #19 Re: performance shift and TCS
    Jul 2008
    sumter,south carolina
    i have an 02 gtp,i had a toggle switch run up under the left side of dashboard to engage and disengage.easy access and i had no probs with it so far.
    02 GTP with mods 05 GP for DD
  20. #20 Re: performance shift and TCS
    SE Level Member 2001camaroB4C's Avatar
    Quote Originally Posted by iamwhutiam003 View Post
    two things:
    1) I dont think my car is in any way in need of traction control. Its nice in the snow I guess on my other car. i never have it on. I dont like what it makes the car do in the event that it it does lose traction.
    In my other car tcs or asr or whatever it is called has almost cased me to get hit on more then one occation. I try to pull out of a parking lot or something when it is a little wet or something, I get a little spin the car applies brakes and rejects throttle making it so I can not get up to speed of traffic. If disabeling it didnt cost money I would no longer have it.
    I could see it being useful on a really high performance track car with a much more sophisticated tcs system for getting through turns with out spinning. But imo has no place in my street car. Id rather have it spin and have the car do something that I can correct then just stop or react differently then it should to my imput.
    2) No shouldnt decrease fuel mileage. Should make the trany last longer by lowering how much it slips on shifts. As has been said fuel mileage is way more effected by your right foot.
    2001 A4 Camaro B4C, 1.94 60ft - 8.48 1/8@84.13 - 13.17@104.29, should go faster with a better track and no ses light.
    And now a 98 Grand Prix
  1. Adding Performance Shift [*]
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2014, 06:44 PM
  2. performance shift WTH?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 07-08-2008, 09:44 PM
  3. performance shift
    By Scott B in forum General Tech Discussion
    Last Post: 06-29-2008, 08:40 PM
  4. ?? about performance shift button
    By DesQ27 in forum Off Topic Discussion
    Last Post: 06-29-2008, 01:13 PM
  5. why did they get rid of the performance shift ?
    Last Post: 01-17-2008, 02:18 PM
