Thread: Cleaning a MAF sensor?
Results 1 to 4 of 4
  1. #1 Cleaning a MAF sensor?
    SE Level Member TronCarter's Avatar
    Kalamazoo, Michigan
    I get the P0102 code and have done some searching around for answers. I have seen suggestions to first try a new air cleaner, then see if the code returns. Second try to clean the MAF sensor. Third, replace the MAF sensor.
    Does anyone have instructions on how to clean a MAF sensor? Is it even worth trying?
    Tron
  2. #2 Re: Cleaning a MAF sensor?
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    Its real easy. You just take out the 3 screws and pull the top of the sensor off. Theres to little metal pins that have a wire attached to the top of them. They are fragile. Get some CRC MAF Sensor Cleaner and spray them down till they are shiny. Let em air dry and put it back in.
    Be real careful when you are pulling the maf sensor off, pull it straight out so you don't hit the pins on anything.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  3. #3 Re: Cleaning a MAF sensor?
    Kalamazoo, Michigan
    Thank you, that sounds easy. I bought the cleaner and went to do it today but found what I believe to be torx screws, which I don't have the tool for. Can someone tell me what the proper driver is for those, so when I go to the store I get the right one.
    Thanks,
    Tron
  4. #4 Re: Cleaning a MAF sensor?
    Moore, Oklahoma
    Can't remember the exact size right off, its at home. I do know its not a regular Torx bit its specifically called a "Safety Torx". If you have regular torx laying around, match up what you got and get the exact same size but in the safety version (which will have a hole in the center for the nipple)...
    Shawn W. Larsen
  1. cleaning up the outside
    By crshoveride in forum General Tech Discussion
    Last Post: 06-03-2011, 09:09 AM
  2. sensor cleaning
    By stanwich in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-21-2008, 09:11 PM
  3. Cleaning up engine
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 09-25-2008, 03:26 PM
  4. cleaning a sub
    By MTXGTP in forum Audio, Security & Visual Electronics
    Last Post: 07-11-2008, 01:53 PM
  5. Engine Cleaning
    By wrfdff4 in forum Visual/Body Modifications
    Last Post: 03-19-2008, 09:04 PM
