Thread: loud tapping noise
Results 1 to 13 of 13
blown98gtp loud tapping noise 03-01-2009, 04:09 PM
Guest Re: loud tapping noise 03-01-2009, 04:13 PM
blown98gtp Re: loud tapping noise 03-01-2009, 07:00 PM
Sabrewings Re: loud tapping noise 03-01-2009, 07:18 PM
Guest Re: loud tapping noise 03-01-2009, 07:52 PM
blown98gtp Re: loud tapping noise 03-01-2009, 07:53 PM
blown98gtp Re: loud tapping noise 03-01-2009, 07:57 PM
Blown97 Re: loud tapping noise 03-02-2009, 04:01 AM
blown98gtp Re: loud tapping noise 03-02-2009, 07:19 AM
Guest Re: loud tapping noise 03-02-2009, 10:35 AM
fst Re: loud tapping noise 03-02-2009, 10:54 AM
Guest Re: loud tapping noise 03-02-2009, 12:00 PM
blown98gtp Re: loud tapping noise 03-04-2009, 03:40 PM
  1. #1 Re: loud tapping noise
    SE Level Member blown98gtp's Avatar
    Feb 2009
    iowa
    Earlier in the day, I had pulled the fuel rail off, the piece of plastic had broken off of the connector and fell down into the injector boss. I did not see it when I put the fuel rail back on, and when I pushed the injectors into place it just wedged itself in between the injector and the head. When I took the fuel rail off, the o-ring was tore, so I don't know how it wasn't spraying fuel all over. By the way, I put the fuel rail back on and the noise is still there.
    98 gtp:L36/GenV/S1X/Pacesetters/FWI/Intense tune/timing commander/104s/P&P heads/DevilsOwn alky kit/ZEX dry shot/42.5#/shift kit/ScanGauge
  2. #2 Re: loud tapping noise
    Feb 2009
    iowa
    I hope it's just a lifter, but this is a loud tapping noise. Lifters that I've heard before are more of a ticking noise. Bearings are more of a knock.
  1. Loud whistling noise
    By Minno in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2009, 09:04 PM
  2. My engine tapping noise with Video
    By 04CompG in forum General Tech Discussion
    Last Post: 12-12-2008, 02:57 PM
  3. Tapping noise at idle.
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-14-2008, 09:43 AM
  4. Loud noise above 45mph
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 11-09-2008, 10:03 PM
  5. HELP: tapping noise!
    By fst in forum General Tech Discussion
    Last Post: 08-28-2008, 10:46 PM
