Thread: Help IGNITION KEY PROBLEM
Results 1 to 3 of 3
cool50 Help IGNITION KEY PROBLEM 02-28-2009, 10:29 PM
Guest Re: Help IGNITION KEY PROBLEM 02-28-2009, 11:10 PM
BrokeMofugga Re: Help IGNITION KEY PROBLEM 02-28-2009, 11:57 PM
  1. #1 Help IGNITION KEY PROBLEM
    Feb 2009
    chicago
    sometimes my ignition key won't go all the way back and the key is stuck in the ignition I have a 2000 gtp, any ideas?
  2. #2 Re: Help IGNITION KEY PROBLEM
    TDCRacing
    Guest
    Please be sure you're posting in the correct section to ensure you're getting you're getting the best results for you're questions.
  3. #3 Re: Help IGNITION KEY PROBLEM
    Jan 2009
    Brandon FL
    I dont know if all GTPs have or not?but right underneith the colum the is an access hole and i put my finger in there and bend it towards the steering wheel and i can feel somthing like a spring,and i take and push up on it with the top of my finger and then it clicks so then im able to turn the key all the way back.the girl i bought the car from showed me this trick.gl man
  1. I can't take my key out of the ignition!
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 09-06-2010, 11:10 AM
  2. Ignition Problem.
    By dbean in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2008, 07:49 PM
  3. Key stuck in ignition-
    By checkm8gtp in forum General Tech Discussion
    Last Post: 02-21-2008, 07:46 PM
  4. Need More Help, Ignition
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-28-2008, 12:17 AM
